100 Series Wheel Bearings
Submitted: Wednesday, Sep 28, 2005 at 22:40
ThreadID: 26851 Views:3497 Replies:4 FollowUps:7
Was quoted $70 for wheel bearing service kit which includes lock tabs dust seals and gaskets from Toyota, how's the price sound?
Can some one let me know what the lock nut size is ?
Reply By: Footloose - Wednesday, Sep 28, 2005 at 22:54
To have my two front wheel bearings and seals done commercially cost me $450 + and I'm told it usually takes between 4-6 hours. So that kit sounds cheep to me.
AnswerID: 132257
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 08:20
Footy,
That sounds like you'd be having the axle seals changed and swivel hubs regreased as well.
FollowupID: 386544
Reply By: nuboy - Wednesday, Sep 28, 2005 at 23:32
Thanks for the reply, I'm quite supprised at the commercial cost, makes the $70 sound reasonable. I was quoted $900 the other day for a Major service which if you can believe it was to include front bearings coolant change engine oil and filter change + fuel filters.
AnswerID: 132264
Reply By: nuboy - Wednesday, Sep 28, 2005 at 23:51
Still chasing the lock nut size for the front wheel bearings, if any one can help ?
AnswerID: 132266
Follow Up By: Member - Davoe (Widgiemooltha) - Thursday, Sep 29, 2005 at 00:42
Dont know exactly but it is big as in not in the socket section of supercrap. It is a special tool and hangs behind the counter of the local Auto1 shop just go in to your auto parts store and ask for it
FollowupID: 386530
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 08:26
The locknut can be easily loosened by tapping the edge with a screwdriver and hammer. The diameter is about 55mm from memory - don't quote me on that.
You can either buy a special socket as Davoe has suggested, or make your own. To make your own, just remove the locknut and bend a piece of 3mm thick flat mild steel around it, and weld it up to be a socket. The locknut is never done up tight.
If you want aftermarket bearings, I bought the same complete set (Timken bearings) for under $40 a few months back. They were Terrain Tamer brand from Adelaide truck and 4wd Spares.
FollowupID: 386546
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 08:33
Nuboy,
All the above replies also refer to the Rigid Front End Cruisers. You didn't state whether yours is IFS or rigid front end
FollowupID: 386547
Reply By: nuboy - Thursday, Sep 29, 2005 at 10:01
Thanks Phil, vehicle is a 100 series 1999 and has a rigid front end.
I have only had it for a week or so and am real new to the game ( 1st 4X4 ) Brought the beast 212K's 4.2 at an auction house in Perth for $26K It was a Power Utilities vehicle up to 160K's with a full service history. It then went to Darwin. It has a swag of accessories on it which I had to price up for insurance purposes at ($16k +) I'm finding the Forum real helpful with a lot of usefull info.
Lastly I would like to pick up a manual and would like to know what is the go ?
AnswerID: 132311
Follow Up By: David/Dave - Thursday, Sep 29, 2005 at 10:39
The easiest place for a manual is probably the dealers, or you could try e-bay.
On parts, give Craig a call at United Parts International in Maddington (phone 93586878). His prices are good and he's pretty straight with advice. He helped me out a lot with my old HJ47, and from what I can gather the 100 series are his bread and butter.
Don't forget labour costs are around $100/hour at the dealers, $60-$80/hr elsewhere. The actual parts themselves are a small component of the cost, so if you're prepared to do it yourself then you'll save plenty.
E-mail cw@unitedparts.com.au
cheers,
Dave.
FollowupID: 386566
Follow Up By: Member - Davoe (Widgiemooltha) - Thursday, Sep 29, 2005 at 11:00
If you just want the service book so you can get it stamped when serviced - they are available from the dealer and have a spare parts no
If you want it so you know what to service then buy the gregorys manuel It will give you all the how too and also provide all the info on what needs chamging at what interval.
My best tip is buy a 15/16 socket for doing your diff and gearbox oils and make sure you can undo the filler plugs before draining the oil
FollowupID: 386572
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 21:08
Nuboy,
If you start calling it a 105series, people will know exactly what vehicle you have. All the 105series have a rigid front end, while the actual 100series is IFS.
I presume yours is a 1Hz diesel - I've always found the Gregorys manuals better than the others.
the LCOOL site will have a lot of useful stuff for DIY servicing:
100scool technical
FollowupID: 386691
