79 Series TD factory snorkel
Submitted: Thursday, Sep 29, 2005 at 10:21
ThreadID: 26861 Views:5150 Replies:4 FollowUps:3
G'day all, I have recently bought a new 79 series turbo disel ute. It comes standard with a factory snorkel, assuming all fittings are tight are these water tight. I have heard they are rated for dust only. Any information from people with this vehicle would be appreciated.
Thanks and Regards
Jack
Reply By: Member - Karl - Thursday, Sep 29, 2005 at 10:51
Yes it should be water tight - unless the water is above your roof line - but by then you would be in serious trouble any way.
The factory fitted snorkles (and other after market equipment such as tow bars etc) are made by the after market manufacturers and re-badged by Toyota (and Nissan etc), sold as a genuine product and cost more.
Karl
AnswerID: 132316
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 15:57
Not on the 79series
FollowupID: 386612
Reply By: In Good Time - Thursday, Sep 29, 2005 at 13:01
Jack
Did here of someone drowning a TD79 Cannot rember where, but the problem was due to the joins in the snorkel where it goes throught the guard not being sealed correctly. Apparently the owner had to where the cost of repair.
Personaly I would remove the snorkel myself and check that its sealed correctly.
Also I am currently in the process of about to order a TD79RV, just wondered what you considered to be a good price for this vehicle on the road drive away.
Pete.
AnswerID: 132329
Follow Up By: Jack79TD - Thursday, Sep 29, 2005 at 13:13
Pete
Not sure about the RV but purchased mine 29th June for $50,700
2005 79TD, Genuine steel winch bar, HD tow bar, Air (should be standard but isn't), steel tray, all onroads dealer delivery etc.
Not sure how others have gone but this was the best i could get.
Jack
FollowupID: 386593
Follow Up By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 16:34
I also got quoted on new vehicles in Nov 2004. Most dealers would immediately cut $5000 off RRP if paying cash, and no trade. RV was $3600 dearer from memory. Worth it just for the wheels,flares and bucket seats.
Worth thinking about the factory diff locks too - $2400 extra, but it will take 3 months to get it.
phil
FollowupID: 386624
Reply By: Troopie - Thursday, Sep 29, 2005 at 14:02
G'day There
I would pull the snorkel off and seal up all the joins yourself. This was the strong recommendation I got from my mechanic (large reputable 4wd specialist). His view is that while it should be ok from the factory - they have failed so why take the risk.
When I pulled mine a part - I found the foam they use to seal around the joins in the snorkel to be of a thin, and permeable open weave foam. I removed all this, cleaned and lightly sanded the area of the join to rough the surface and encourage the sealant to stick. I used a high stress flexible sealant when I put it all back together.
Also, if you are really keen - seal up the dust cup at the bottom of the filter barrel. This is not water sealed - so if you happened to stop in deep water and the engine bay fills - apparently water can enter the filter barrel via the seal around this cup. Again, I sealed it - but make sure you remove and clean it regularly then reseal.
AnswerID: 132340
Reply By: Member - Phil G (SA) - Thursday, Sep 29, 2005 at 16:06
I did the same as Troopie above. The 79series comes standard with a "dust" snorkel from Japan, and has a fording depth of 700mm. Its a 2 piece snorkel, so you have to seal it up to be sure.
Good vehicle choice Jack. You'll love it.
AnswerID: 132355
