AnswerID: 132823 Submitted: Monday, Oct 03, 2005 at 15:22
BenSpoon
replied:
I picked up the opposite lock battery tray for my dual batt as it came in a little cheaper than the genuine thing. The OL one came with an extra piece of metal bent up which would be easy to make.
It is a C- Channel piece about 20cm long, 5cm wide and 4cm deep. It has 2x holes drilled in each side- on one side you bolt it to those capive nuts on your car you mentioned- there are several (on both sides of the engine bay too), and on the other side of the C channel you bolt on your washer bottle. It just spaces it from the engine bay wall and acts as a seccure adaptor plate to bolt on to.
The heat has not been an issue- if you tuck it in behind the air box it stays
cool. I have a bent up metal bar fixed to 2 capive nuts on the other side so there is complete airflow around the isolator, but I dont think its much of a problem anyway.
 | Dolphin: The other white meat |
Reply 1 of 4
