Site Search
Section Image
Jackaroo diesel fault
Submitted: Tuesday, Oct 04, 2005 at 08:37
Skipper
Just a word of warning to owners of the 3.0.litre turbo Isuzu diesel that they can develop a crack in the engine block behind No 4 cylinder that extends through from the cylinder to the coolant gallery. This happened to me while towing a caravan recently and caused coolant to be pushed out of the radiator into the coolant recovery bottle during each day's driving. Luckily the car was still covered by warranty and the engine block was replaced by a new version with thicker walls around the cylinders but potentially could have cost up to $8,000 for parts and labour and the car has only covered 50,000 kms! I believe that Holdens /Isuzu have recognised this problem and it will be interesting to see if older engines that develop the same problem are also covered for this - it is only a problem when placing the engine under high load conditions such as extended towing trips.
Advertisement
ThreadID: 26973 Replies: 2
Views: 864 FollowUps: 1
AnswerID: 132944   Submitted: Tuesday, Oct 04, 2005 at 09:11
herkman replied:
It is important that the correct oil be used in the engine, other wise you will have hard starting.
Col Tigwell
Reply 1 of 2
AnswerID: 133010   Submitted: Tuesday, Oct 04, 2005 at 17:35
Member - Bradley replied:
Thanks for that Skip, if you wouldnt mind, could you pop over to australia4wd.com and post this in the isuzu section under the dedicated 3.0td section, you will also find heaps of info for your motor there, and some good tips.
cheers Brad
Click Image to Enlarge
On the lookout for 98 onwards v6 auto jack.
Reply 2 of 2
FollowupID: 387320   Submitted: Wednesday, Oct 05, 2005 at 09:05
Skipper posted:
Hi Brad,
A good suggestion and I have just done that, it looks like a very good site. I hope my bit helps as I would have liked to have been told about something like this, there was absolutely no indication that this was going to be a problem, as we have taken our caravan away twice before with no trouble at all, Holden's did not let a lot of info out to me but the techo had seen the same thing in two other engines and knew what he was looking at.
Happy trails!
Skipper
