Site Search
Section Image
Terracan climate control
Submitted: Tuesday, Oct 04, 2005 at 21:46
chatsbury
Has anyone who owns aTerracan Highlander had trouble with climate control. On long trips ours will pack it in fan will be on high but no air is delivered to cabin. If you stop for an hour or so system will work fine again. I noticed after driving all day and pulled up at motel water dripprd out of airconditioner for about 2hrs which leads me to suspect system is forming ice within it which blocks air flow.
Would appreciate any advice on this matter
Chats
Advertisement
ThreadID: 26998 Replies: 4
Views: 452 FollowUps: 1
AnswerID: 133063   Submitted: Tuesday, Oct 04, 2005 at 22:02
Moz replied:
G'day Chats,
Sounds like your theory could be right.
The problem is probably with the thermostat.
If it is, then it could be a bit of a job to replace.
Is it under warranty? A dealer should be able sort it out.
The thermostat usually sit under the dash mounted on to the
A/C unit and a sensor wire runs in inside the unit and sits against
the evapourator. If it is not situated correctly or if the t/stat has failed
electrically then it will need to be replaced which may requires the dash
to be removed to access the A/C unit.
As I said it's a job to do.
Cheers Moz
Reply 1 of 4
AnswerID: 133108   Submitted: Wednesday, Oct 05, 2005 at 09:15
herkman replied:
yes I suspect that too, what is happening is the system just keeps pumping the cold air, until it freezes up. When you stop the ice melts and off you again, until the whole cycle starts again.
So the dealer says he cannot duplicate the fault, try and freeze it up for when you get there. Whilst water coming from the drain is normal, large amounts indicate the unit is freezing up.
Col Tigwell
Reply 2 of 4
FollowupID: 387390   Submitted: Wednesday, Oct 05, 2005 at 20:18
chatsbury posted:
Thanks guys for your info very helpful to explain to dealer whats is probably happening as it will be difficult to replicate problem
Cheers Chats
AnswerID: 133144   Submitted: Wednesday, Oct 05, 2005 at 16:19
Member - Wim (Qld) replied:
chatsbury.
Problem may also be short on gas. Check sight glass for bubbles.
Click Image to Enlarge
Old Man Grevillea suspension upgrade CSR 08
June 2010 - Back to the Northern Simpson
VKS 737 Mobile 0091
Selcall 0091
Reply 3 of 4
AnswerID: 133190   Submitted: Wednesday, Oct 05, 2005 at 22:18
Member - Duncan W (WA) replied:
Try here, we Terracan owners have a forum at:
www.terracan.australia4wd.com
pretty sure climate control in the Highlander's been discussed. I have the base model so can't help otherwise.
Dunc
YAMARNA STATION
Dunc
Reply 4 of 4
Activities Index
Barossa Valley & Adelaide Hills Wine Tour Barossa Valley & Adelaide Hills Wine Tour
Adelaide - SA
For Wine or Reason specialize in personalized guided Wine Tours, perfect for corporate clients or th
See Melbourne and Beyond Attraction Pass 2 days See Melbourne and Beyond Attraction Pass 2 da
Melbourne - VIC
Attraction pass for Melbourne & Beyond. Over $1000 worth of admission fees.
Cradle Mountain Overland Track Tour Cradle Mountain Overland Track Tour
Devonport and North West - TAS
The Overland Track is Australia's premier extended bushwalk and one of Tasmanian Expeditions most po
V8 Race Buggy Hot Laps - Melbourne V8 Race Buggy Hot Laps - Melbourne
Melbourne - VIC
Experience the power of a V8 Race Buggy zooming around the track.
Book Now - Things To Do
