Engel smell
Submitted: Wednesday, Oct 05, 2005 at 22:00
ThreadID: 27018 Views:13864 Replies:20 FollowUps:19
I lent my Engle fridge to a friend & they forgot that they had left bait in it for a week with the fridge turned off. Any ideas as to how I can get the smell of rotten fish out, we have used bi-carb soda and vanilla essence but the smell is still there
regards
Steve
Reply By: Member - Roachie (SA) - Wednesday, Oct 05, 2005 at 22:03
The bi-carb is the way to go afaik......but you need to leave a saucer of it in the bottom and run the fridge continuously for however long it takes.
Vanilla essence is also good for a moderate smell, but that is only good for wiping the inside of the fridge.
These are just my personal experiences.
Roachie
AnswerID: 133186
Follow Up By: jendav - Wednesday, Oct 05, 2005 at 22:10
Charcoal is very good too, i use it in my shed fridge and put some in the engel after trips, seems to absorb all the odors.
Good luck
Dave.
FollowupID: 387402
Reply By: gramps - Wednesday, Oct 05, 2005 at 22:13
Somebody previously posted on here about a pineapple cut in half ( or more ?) sitting in an empty container to remove the smell of cigarette smoke from a vehicle. Might be worth a try if all else fails :)
AnswerID: 133187
Reply By: stevep - Wednesday, Oct 05, 2005 at 22:28
Thanks, i'll give these a try and hopefully no more smell.
Stev
AnswerID: 133193
Reply By: Tim HJ61 (WA) - Wednesday, Oct 05, 2005 at 22:44
My SWMBO suggests you stuff the Engel full of dirty socks. She figures it might get rid of the fish smell.
She's got no idea how to get rid of the smell of dirty socks! :-)
Steve, I really wish you all the best with this awful challenge - it's a terrible, I was going to say rotten but thought that might be insensitive..... thing to happen.
Please be aware when fridge's break down and food goes rotten inside, they are usually just tossed out and never tried to be repaired due in part to the way the smell gets into the plastic. It might be different if the bait had stayed cold, but with the fridge off and sealed up, a lot of heat would have been generated and permeated the plastic. Maybe you will need to heat the plastic up again at the same time as using the charcoal, pineapple, bi carb, vanilla etc etc to remove the odour. Never had to do it, but maybe leaving it in the sun with the lid off might help.
You could also invite your friends camping lots and use the Engel to store their food. Might help them contribute to a new one......
Tim
AnswerID: 133199
Follow Up By: stevep - Wednesday, Oct 05, 2005 at 22:48
I like your idea, I don't eat fish & hate the smell so if he has to have his food smelling of bait he will never leave it in the fridge again.
Steve
FollowupID: 387406
Follow Up By: Nudenut - Thursday, Oct 06, 2005 at 07:01
if they need to toss them out it is because the smell has been absorbed by the insulation...usually the old glass insulation type....if in a domestic a fridge/freezer the juices from the thawed out delicacies would also find a way into the insulation cavity generally via the plastic mouldings around the edge.
polyurathane type insulation may not absorb odours to such a degree, and with these type of fridges having a sealed innner liner, juices should not be able to enter the insulation cavity
FollowupID: 387433
Follow Up By: Member - Roachie (SA) - Thursday, Oct 06, 2005 at 20:37
Tim's comment has given me an idea.............
If you can't get rid of the smell because it has permiated the plastic tub, you may be able to speak to a engel dealer/repairer who may be able to supply you with the tub from a engel which has a carked motor etc!
FollowupID: 387544
Follow Up By: Nudenut - Thursday, Oct 06, 2005 at 21:08
yep the idea sounds sound..until you factor in labour costs to:
reclaim refrigerant ..from both systems
remove compressor from fouled system
remove compressor from failed system
insert compressor into which system...(sounds like my bank) .....but i've forgotten which one needed the transplant....hehehe
evacuate the recipient and recharge with refrigerant
all at around $70-90 per hour(cheaper than bank managers) plus other material...
FollowupID: 387559
Reply By: joc45 - Wednesday, Oct 05, 2005 at 23:09
Hi Steve, I'd give it back to your "friend" and tell him to return it when the smell has been removed.
Personally, I wouldn't be loaning out that sort of equipment. Someone who is that slack with the care of borrowed equipment doesn't deserve your kindness.
I know a car fridge rental co. wouldn't be as lenient, and would probably charge for the replacement of the fridge.
Am I being too unkind?
Cheers, Gerry
AnswerID: 133204
Follow Up By: Eric from Cape York Connections - Thursday, Oct 06, 2005 at 06:07
Gerry im with you as per usuall lend somthing they stuff it you spend hours of your time fixing it.
All the best
Eric
FollowupID: 387429
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Oct 05, 2005 at 23:27
Simple I have left bait in eskies plenty of times, 100% bleach and lots of it
AnswerID: 133205
Reply By: muzzgit (WA) - Wednesday, Oct 05, 2005 at 23:35
My SWMBO recons that you will need to leave it open for quite a while, wiping it out with white vinigar regularly. If you must slose it up, make sure it is cold and put an onion cut into two inside. The onion will absorb lots of the bad smells but you will need to replace the onion every 4 or 5 days for it to work. She regularly puts onion peices in the house fridge if we've had garlic or strong smelling food in it. IT DOES WORK.
I recon you should print this page of responses, give it to your mate and get him to fix it, or replace it.
Lets face it, that was a rather expensive mistake that you shouldn't have to pay for. Fair's fair mate !!!
AnswerID: 133207
Reply By: Member - Andrew(WA) - Wednesday, Oct 05, 2005 at 23:51
scoop out half a lemon and fill it with salt. Place it in the fridge (turned on) for a few days and see how you go!
Saw it TV....never tried it myself.
AnswerID: 133211
Reply By: Member - Davoe (Widgiemooltha) - Thursday, Oct 06, 2005 at 01:13
Thought from left of field. Did anyone see the Myth Busters where they put 2 pigs in a car in a sea container for a month to see if they could get it back to saleable condition (still the funniest thing i have ever seen on TV) well a guy that makes his living out of cleaning up places that have had long dead bodys put them onto some sort of enzyme cleaner
- does anyone remember what that was?
(It should be noted they couldnt get the car back to a reasnable saleable condition- Myth plausable)
AnswerID: 133213
Follow Up By: crewser - Thursday, Oct 06, 2005 at 18:34
They couldnt even get the car to start again
FollowupID: 387521
Follow Up By: Al & Mrs Al (Vic) - Thursday, Oct 06, 2005 at 20:52
they have a thing for dead pigs those dues....hahahhah
FollowupID: 387548
Reply By: Nudenut - Thursday, Oct 06, 2005 at 07:05
take the fridge to your mates place and tell him to get rid of the smell....if they cant do it (And Permenantly) by the time you need to use it the best option is to give it to your mate and demand a new replacement!!!
AnswerID: 133227
Follow Up By: Member - Chrispy (NSW) - Thursday, Oct 06, 2005 at 07:53
I agree.
1) Never lend expensive things to friends - it's a sure recipe to lose either your stuff or your friends.
2) If you do, and they wreck your stuff, accept your loss - of either your stuff OR your friends - NOT both. Get it REPLACED!!!
FollowupID: 387439
Reply By: The Explorer - Thursday, Oct 06, 2005 at 09:37
Hello - I have heard that Vanilla Essence is the go (ie wipe over inside with it) - never tried it myself.
AnswerID: 133250
Reply By: V8Diesel - Thursday, Oct 06, 2005 at 09:40
My rule is "you f#*k it - you fix it"
If it still smells, guess what - you're mate has bought himself a secondhand Engel that smells of fish for future trips and you get a new one that doesn't stink. If he doesn't think that's fair, he's not a mate anyway.
Good suggestion about printing this out and showing him too.
BTW, do you know the rule of the three M's when it comes to lending things?
It goes something like this..........
The three things you never loan out are your motorcar, mower or missus because they will always come backed f#*ked! The workshop foreman told me that when I was 18 and I've never forgotten it.
AnswerID: 133252
Follow Up By: Nudenut - Thursday, Oct 06, 2005 at 21:10
i wouldntt care less if the last two come back at all..hahaha
FollowupID: 387561
Follow Up By: Nudenut - Thursday, Oct 06, 2005 at 21:13
er..that should read
i wouldntt care less if the last two didnt come back at all
FollowupID: 387565
Follow Up By: Nudenut - Thursday, Oct 06, 2005 at 21:15
geez....almost forgot i was in love
FollowupID: 387568
Follow Up By: joc45 - Friday, Oct 07, 2005 at 11:25
wot, in love with that face? lol!
FollowupID: 387650
Follow Up By: Nudenut - Friday, Oct 07, 2005 at 12:20
nobody else will ever be...s i might as well
FollowupID: 387662
Reply By: shaggy - Thursday, Oct 06, 2005 at 12:46
Hi there mate,
do not worry too much. You can get this smell out. I had a similar experience when my freezer full of dead rats and mice decided to trip the safety switch in the middle of summer. After about a week, when it was time to feed the python, I went to the freezer and wondered what all the flies were around for. Turns out they can pick up the smell of rancid flesh before I could.
Anyway, it stunk like you would not believe, and there was a good inch of decomposition juices in the bottom.
So first things first, hose it out. Second thing to do is like someone suggested. Sodium hypochloride (liquid pool chlorine 12.5 v/v)which disassociates into chlorine gas upon mixing with enough water. You may need about 500 ppm concentration or more. About a cup into a bucket will vastly exceed this level, and kill all this anaerobic bacteria.
An engel is made with polypropylene walls I assume? It does not sound like fiberglass walls, because fiberglass is a lot easier to clean, being much less porous.
Anyway, wipe this down well with this solution, and leave the moist fridge closed for about a day. Then hose it out again, and you should have gotten all the bacteria dead.
Then sunlight becomes your friend. The heat of the sun will remove any remaining chlorine gas trapped in the walls, and then you want the UV B to take over from the chlorine bacteria destruction.
You will need to repeat this several times. If you have access to ozone generator, it will also help. Put it in the fridge with the door closed. These can be made with a high voltage source (20,000 V and some aluminium foil and brine). LEt me know if it still stinks and I could send you plans for it.
The fridge is recoverable, no problems, but it may take a few weeks.
Shaggy
AnswerID: 133278
Follow Up By: Lyds- Thursday, Oct 06, 2005 at 14:21
Hey shaggy, were you on a Sydney radio station talking about your freezer contents?
FollowupID: 387492
Follow Up By: Eric from Cape York Connections - Thursday, Oct 06, 2005 at 18:24
How are you lyds.
Have you any trips planed comming up.
All the best
Eric
FollowupID: 387519
Follow Up By: Lyds- Friday, Oct 07, 2005 at 09:05
Good thanks Eric.
I've shot you an email.
FollowupID: 387638
Follow Up By: shaggy - Friday, Oct 07, 2005 at 09:21
No, I have not been on any sydney radio station. Must be someone else.
FollowupID: 387643
Reply By: The Rambler( W.A.) - Thursday, Oct 06, 2005 at 14:35
Steve,
I am surprised no one suggested the old trick of using tea bags to get rid of the smell.Just put a few tea bags in the fridge and replace every day yill smell has gone.They also work well when storing things in the tropics to prevent mould when it gets very humid.---good luck
AnswerID: 133297
Follow Up By: stevep - Thursday, Oct 06, 2005 at 20:33
Thanks for eveyones ideas, i'll try them all and if all else fails someone may have a fishing fridge & I will have a new one.
Steve
FollowupID: 387542
Reply By: Michael ( Moss Vale NSW) - Thursday, Oct 06, 2005 at 20:30
Vinegar to get rid of the smell and a spray bottle of vanilla to make it smell nice
AnswerID: 133333
Reply By: Spade Newsom - Thursday, Oct 06, 2005 at 21:51
stevep,
Give this a go.
Put a few drops of lavender oil on a couple of tea bags. Hang the tea bags on the fan inlet and run the fridge. Change the tea bags every few days.
This I heard on ABC Brisbane night radio a couple of months back. There is a lady who does a half hour about once a fortnight where people ring in with unmentionable and immovable stains and smells on almost anything. She is a professional restorer. I have listened many times and I have never heard her stumped with a challenge. You could possibly try contact the radio station to get her details or find out when she will be on and phone in. I have searched through the ABC web site but can't find anything.
Hope this helps. Good luck.
AnswerID: 133348
Reply By: Spade Newsom - Thursday, Oct 06, 2005 at 21:53
stevep,
Give this a go.
(Sorry this will only work for a thermo electric fridge. You would have to put the tea bags inside for a compressor fridge. Worth trying to contact these people anyway)
AnswerID: 133349
Reply By: Wombat - Friday, Oct 07, 2005 at 12:13
Have you tried Nilodour?
AnswerID: 133421
Reply By: Spade Newsom - Tuesday, Oct 11, 2005 at 22:31
Steve,
You may still be interested regarding my last reply. I found the name of the lady who is on ABC radio who WILL have the answer for you. Her name is Shannon Lush and it looks like she is on ABC radio in every state. She has a web site
shannonlush.com
I tried to ring in on Brisbane radio tonight with the pungent fridge but couldn't get on - sorry. I did find out though that you can use milk curd and white spirits to remove permanant marker from clothes and that to remove smoke stains from walls you can use cigarette ash and water. "I'll be buggered" was the response from the little old lady who phoned in.
Maybe you could post how successful you were getting the smell out. Most punters would have the odd smell in their Engel or Waeco.
AnswerID: 134219
Reply By: stevep - Tuesday, Oct 11, 2005 at 22:53
Many thanks for your help and follow up. I have tried the teabags, bi-carb soda, fridge freshener & lemon, the smell is not as bad but it is still there.
I will try the website and see if she can help.
Once again I really appreciate your help.
Steve
AnswerID: 134225
