Compressor
Submitted: Friday, Oct 07, 2005 at 01:04
joe1
Hi there,could someone out there tell me if the Thomas blue tongue compressor has the option for a pressure cut out switch.
Joe
Reply By: Leroy - Friday, Oct 07, 2005 at 09:11
I think you will find the presure cut out switch is only on models that has a reservoir like one of the ARB compressors.
Leroy
133396
Reply By: Russel & Mary - Friday, Oct 07, 2005 at 09:34
Leroy is right. The Thomas doesn't come with it's own reservoir. If you are running your Thomas into an air
tank then you can fit a pressure switch. I've got
mine running into a 20litre
tank under the back
seat area of the Navara bolted to the chassis. I have a pressure relief valve in line like the ones on a workshop compressor so that if I don't turn off the Thomas, then at about 90psi the valve opens up. Rus.
133403
Reply By: joe1 - Sunday, Oct 09, 2005 at 01:35
Ok thanks for the above info.
Joe
133718
