pathy across the simpson
Submitted: Friday, Oct 07, 2005 at 18:08
ingo57
I am planning a trip across the simpson next year with my wife and 2 year old son. We will be in a 02 nissan pathfinder TI which Ive allready raised 1 1/2 inchs at the front and 2 inchs in the rear, rancho shocks and struts and BF goodrich all terrains, the rest is pretty standard. We will be taking 40 litres of
water, an engel fridge and 60 litres extra feul.
Has any body crossed the simpson in a pathy that can share there preperations, and is 130 litres of feul adequate for this trip. Any additional information would be greatly appreciated
Reply By: Moggs - Friday, Oct 07, 2005 at 18:20
I'd be taking a hell of a lot more fuel than that for the Pathy - they are very thirsty - especially in sand.
Maybe ask in the Pathfinder club
forum - I am sure you will get the right help there. Just go to www.pcoa.org.au and follow the links to the
forum.
133494
Follow Up By: Member - Crazie (VIC) - Friday, Oct 07, 2005 at 20:44
Have to agree with Moggs, I went across in the jack and used about 130 from Mt Dare to
Birdsville and it was a Pretty easy drive. It is recommended that you take about the 180L to 200L just in case. I carried about 190L.
If you are only going to risk 130L, take more
water just in case.
387730
Follow Up By: Member - Stan (VIC) - Friday, Oct 07, 2005 at 22:44
My Prado used 150L of fuel from
Oodnadatta to
Birdsville, but I was
travelling behind slow moving Patrol :)
You will need more fuel and I about 60L of
water.
387754
Reply By: Footloose - Friday, Oct 07, 2005 at 18:29
40L of
water is fine if you don't have breakdowns and you're not going at Frying Time. Should you be unlucky enough to be broken down by yourselves in the heat you have enough
water for 4 days for the entire trip. Say the breakdown occured on day 2 or 3 and you had to wait a while, you may find it uncomfortable.
133499
Reply By: mfewster - Friday, Oct 07, 2005 at 18:47
We have just been across. I'd be taking more
water than that. The month is important. Sep/October and you can get 40 degrees shade temp and windstorms that dry you to a crisp. We got just this. Any later and it starts to heat up for real. How many days do you want to spend crossing? If you want to look around a bit, you will want more days and more
water. Do you intend washing? How much are you allowing for cooking? We had a team of doctors with us as we were supporting a pushbike race. Their advice was to check your urine regularly. It needed to be "copious and clear". In the conditions we had, that required a good 8 litres of
water a day per person. And if you drink a few beers you need extra
water on top of this! In my opinion you need double the
water you have allowed. If you finish the crossing with 20 litres to spare, that's good organization. Check how you intend storing the
water. It is all too easy to damage taps/containers while bouncing through the rough stuff and find you have lost 20 litres that you were counting on.
133504
Follow Up By: ingo57 - Friday, Oct 07, 2005 at 19:31
Thanks everyone for your imput, We are looking at taking 3 to 4 days to cross the simpson in june 06, we would be washing dishes thats about it. The existing 40 litres of
water is secured in the cargo area, and for cooking we are allowing a little which will be used for washing afterwoods but point taken, most of our meat will be cryovaced and canned and try to
cook dinners with minimal
water.
387717
Reply By: DesF - Friday, Oct 07, 2005 at 20:33
Hi, Just a mention of the fuel for the Pathy, My mate and I ( My 3ltr Man Pajero 89 NF.) We have done several trips together and we just got back from 5.000 ks in Outback Sa & QLD and he managed 7.7ks plt and I got 7.3. But last year we went thru the Vic deserts 2.500ks ( a lot of heavy going ) and I got 6.9kpl and he only got 4.9kpl. It seemed that being auto it was hunting up and down all the time and he nearly ran out before we got
Redcliffe.
WE both have vans and it is the same story , his consumption is increased about 1/3 when towing.
Better to be sure than Sorry Cheers Des.
133529
Reply By: Member - Crazie (VIC) - Friday, Oct 07, 2005 at 20:54
Hi Ingo57
Firstly I would carry both more
water and more fuel. I have a 3.5 V6 Jack and we used about 130L to get across, We had a pretty easy trip, but it could have eassily been alot harder if we got caught in the rain and we would have chewed more fuel. The pathy wont have a problem doing the trip, but make sure you have it planned. It takes longer than you think to do the kms.
Enjoy the Trip, it is awesome, Take more Fuel (About 180L), Sand flag, Eprib, UHF and
water. Stop in and see ruth at
birdsville caravan park and see hi for me.
Ads
133533
Reply By: ingo57 - Saturday, Oct 08, 2005 at 08:28
Rather than spending $1400 on a long range
tank, what are the thoughts of strapping and securing 5 x 20 litre plastic jerrys to the front of the roof cage lying down wrapped in a piece of carpet. I know its been done on the larger 4wds but on a a pathy would you think it would make it too top heavy on the simpson dunes? Ive measured up in the cargo area with all my gear in, and I can achieve squeezing in,another 30 litres of
water. If I was to take any more It would have to go in front of the cargo barrier where I dont want any heavy objects that can get thrown around the cabin.
133602
Follow Up By: Truckster (Vic) - Saturday, Oct 08, 2005 at 10:35
That would be 100+kgs over the front...
I wouldnt personally do it, but I do understand the pain of LRTank prices, its nuts...
387789
Reply By: mfewster - Saturday, Oct 08, 2005 at 19:49
Ingo 57. You haven't mentioned sparewheels. It is good policy to have two spares across the Simpson, so unless you have a carrier, you might be carrying a wheel as
well up top. I'd consider carrying the fuel cans inside, behind the barrier and put lighter but bulkier gear on top, but I understand the reluctance to have petrol inside. (Score 1 for diesels) If using jerry cans, have look at a Tanami pump (small and light) and enough fuel line so you can transfer fuel without having to move your jerry cans too much and tipping and spilling contents while trying to use them. You will be carrying a decent air compressor for the tyres anyway, so just connect it to the Tanami to transfer fuel. Rather than wrapping jerries in carpet, vist you local truck tyre dealer and get some BIG (tractor) tubes that are about to be thrown out, cut them to appropriate length and pull them like socks over the jerries.
After my first Simpson experience I decided my trusty 4runner just couldn't take the gear that I thought was really required for a family doing this sort of trip and changed to a 60 series Cruiser.
If you aren't happy with the fuel/water/gear/weight distribution issues, consider advertising on this network to team up with another vehicle(s) crossing around the same time and share some items around.
133673
Follow Up By: ingo57 - Saturday, Oct 08, 2005 at 22:34
Point taken mfewster, but its my wifes car and she loves it, so I guess selling is not an option at this point. I have around 8 months to prep for this, so I will try to plan the trip thoroughly and work with what we have,Thanks for your tips and advice.
387869
Reply By: mfewster - Saturday, Oct 08, 2005 at 23:06
Sorry ngo, I didn't mean to imply that you should sell the car, I was just sympathizing with the difficulty of planning this trip having tried the same exercise in something of the same dimensions. Suggest trying to team up with someone rather than cut down on
water, fuel and spare
wheels.
133701
