Odometer corrections anyone?
Submitted: Friday, Oct 07, 2005 at 21:16
ThreadID: 27066 Views:3333 Replies:5 FollowUps:8
On asking a fellow forumite a few weeks ago about the fuel economy of his Nissan with the performance gear I relised there may be a discrepency between the actual distance travelled and the corrected (?) GPS numbers. What is the distance you have recorded? I realise that different tyres give different results so do you actually use the odometer or the GPS for the distance in calculations?
I have always used the odometer reading for the fuel economy calculations, but now have found that the odometer is 2.5% out so when the odometer was reading 100 kms the GPS was actually reading 97.5 kms. I will have to redo all my fuel economy numbers......
Reply By: Member - 'Lucy' - Friday, Oct 07, 2005 at 21:31
Moses! you silly old coota.
2.5 in the big picture of what you are talking about fits the definition of a 'bees dick'.
Fill it up, do a 100kms, refill it, then work it out and if it is 12L per 100kms then thats the standard you use from then on until you run the test again.
If you do it over a 1000kms there will be a ever so slight increase in error, but hey! who gives a whatever, its only 25kms in a 1000.
AnswerID: 133540
Reply By: GOB & denny vic member - Friday, Oct 07, 2005 at 21:52
goodday john
i have tried to balance the figures (or cook the books )but if you want to get it really accurte jaycar have a little electronic dohickey(jeez aussies doing ok should have been like this during the ashes sorry about the interuption ) a little dohickey and you can adjust ti so that it adjusts your speedo and i think odometer you can have a look on there site
steve
how are things with you and heather hope you are both keeping well
AnswerID: 133546
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Oct 08, 2005 at 02:26
I am a bit suss of how accurate distance travelled is with GPS I have had reason to dought it a bit previosly
AnswerID: 133589
Follow Up By: Member - Blue (VIC) - Saturday, Oct 08, 2005 at 09:15
Talking to a mate recently, recommended a speedo place to get his cruiser back close to square. Speedo place put a gadget into the speedo drive and got him to drive a measured 100m. By this method the speedo, when the speedo was showing 100kph, actual was 96kph. They made a small gearbox for him which connects to the speedo drive and the cable/transducer plugs into that. He got a new GPS and thought he'd double check his new adjustments, GPS showed, over 3 seperate attempts, 1. odometer 100km, GPS 91km. 2. odometer 101km, GPS 98km. 3. odometer 100km, GPS 105km. It's a Garmin thingy with a colour screen. When he went back to the supplier of the GPS, he was told that terrain had to be taken into account and that if travelling through hilly areas, the GPS will not read accurately.
I personally have no opinion, I don't have a GPS and can't do my own testing. Perhaps it comes down to the quality of the GPS unit...
FollowupID: 387782
Follow Up By: Member - ROTORD - Saturday, Oct 08, 2005 at 11:07
The GPS is accurate to about 10metres , but it measures in a straight line point to point .
FollowupID: 387794
Follow Up By: macka - Saturday, Oct 08, 2005 at 11:07
Hi 3 ltr Patrol.
Course it won't read accurate. Speedo reads over the ground. GPS reads as crow flies.. Will not give true speed or true distance.
Any testing gotta be done on the flat. in straight line.
GPS was, like Sat Nav b4 it. Developed for planes,and misiles. in straight flight .That's why we use them successfully on yachts and fishing boats.
Originally my Speedo reading 9km's slow on GPS. fitted 265 x75 tyres. now reads 2 1/2 to 3 slow. Much nearer to radar readings.
As far as economy goes tank empty. Fill tank. We can't do anything about it. so just keep on doing..
Enjoy everybody.
Macka.
FollowupID: 387795
Follow Up By: Mike Harding - Saturday, Oct 08, 2005 at 14:49
macka posted this followup
Rubbish.
Mike Harding
FollowupID: 387816
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Oct 08, 2005 at 15:03
As Mike has diplomatically put it AKIK GPS is pretty much dead accurate with there as the crow flies directions. I do however dought my Garmin GPS accuracy when measuring distance travelled. It will measure distance travelled vs as the crow flies. Certainly accuracy is further degraded when set to battery save as when you stop it shows you still travelling for some distance. I have found no reason to dought the gps speedo reading. I also heard that the odo works differently to the speed o eg Just because the speedo is 10% out doesnt mean the odo is (different tyres will obviosly make a difference to both) I reckon if these things are a big concern to you when calculating fuel usage Try getting a job that pays more and forget about it and enjoy the travell (last bit tounge in cheek)
FollowupID: 387817
Follow Up By: Member -Dodger - Saturday, Oct 08, 2005 at 16:55
Don't worry be happy.
At least we are keeping the, Arabs , Govt, Oil co's and many more happy n rich.
Just burn the stuff and keep going.
Cheers Dodg.
FollowupID: 387823
Follow Up By: Member - ROTORD - Saturday, Oct 08, 2005 at 17:54
GPS speed is correct because it calculates speed from rate of change of position
FollowupID: 387833
Follow Up By: macka - Sunday, Oct 09, 2005 at 00:03
Hello Mike Harding..
I was talking steepish hills .You find a steep hill and go up it at a decent speed. There will be a variation in readings,'Tween your gps and speedo. (Known differential of course) It can't calc, vertical accurately. Because the Yank's have put in Random, Elevation Variances. To cover their arses from missiles in windows,Bunkers etc.
I've used GPS for 15yrs.and Sat Nav b4 that. Still got my original Garmin 65 on yacht.(Lovely old thing that it is.)along with the Garmin 205 Plotter. That's showing my age. and they're both still going. Which says a lot for Garmin Products and their reliability. Best toy ones on market.
Regards All
Macka
FollowupID: 387881
Reply By: Rock Crawler - Saturday, Oct 08, 2005 at 23:14
it may be out a bit more than a bees wee wee . My onld cruiser was out 11 kms
AnswerID: 133703
Reply By: Spade Newsom - Tuesday, Oct 11, 2005 at 23:10
An old mechanic once told me that an unusual variation in fuel consumption often means something is not happening as it should and worth looking for the problem. Filters (air and fuel), exhaust, fuel supply can all be a culprit.
Thought this advice seemed reasonable.
AnswerID: 134228
