waeco
Submitted: Saturday, Oct 08, 2005 at 06:01
ThreadID: 27076 Views:2080 Replies:2 FollowUps:2
just bought 100 series cruiser and i own 110 litre waeco . just would like to know if any one can tell me if the cigarete lighter in the back ,is the wiring to this lighter big enough to carry the voltage the frige needs ,or do i need to get it rewired Thankyou
Reply By: Shane (QLD) - Saturday, Oct 08, 2005 at 07:04
I have 2005 Terracan & it's sockets are all rated at 120 watts which I can run a WAECO 45 on no trouble, but it's compressor (BD35) is smaller than yours. Best way to find out is to plug it in, and if it cuts out after a couple of minutes you know it's not adequate.
AnswerID: 133595
Reply By: Member - Crazie (VIC) - Saturday, Oct 08, 2005 at 07:46
Hi Dags
The wire that goes to these plugs are not sufficent to run fridges properly. To get the best out of your fridge it is best to re-wire with 6-8mm wire. If you run your fridge on the exsisting plug, you might find the wires will start to melt. It may be best to change the plug on your fridge to a hella plug and put the corresponding socket in your 4wd.
Ads
AnswerID: 133597
Follow Up By: dags666 - Saturday, Oct 08, 2005 at 10:53
thanks for the tips dags
FollowupID: 387790
Follow Up By: 100 Series - Saturday, Oct 08, 2005 at 19:41
The plug in the back of the 100 series only has power when the vehicle is swiched on. No good if you want to run a fridge. Run a separate power cable with fuse directly from the battery
FollowupID: 387844
