charging a deep cycle
Submitted: Saturday, Oct 08, 2005 at 08:11
ThreadID: 27078 Views:2433 Replies:7 FollowUps:1
Hi All,
I am recharging my deep cycle battery via a battery charger off the mains. It seems to be taking an inordinate amount of time to get all of the green bars lit up on the charger.
I beleive it does take longer to charge up a deep cycle but was also wondering what volts the battery should read when charged fully.
The battery is registering 13.1 volts at present, it was at 11.1 when i started charging. As i said thoguh the battery charger still has one more bar of charge to go before it thinks it is fully charged.
The battery is a 75AH, no brand name on it that i could read.
Any info appreciated.
Mark
Reply By: Member - Chrispy (NSW) - Saturday, Oct 08, 2005 at 08:18
How many amps does the charger seem to be supplying - does it have a guage? Take it off charge and let it "rest" for an hour or so. Take a voltage reading then....
AnswerID: 133600
Reply By: Brew69(SA) - Saturday, Oct 08, 2005 at 08:19
Mine reads 13.2 when charged. Are you using a smart charger?
AnswerID: 133601
Reply By: F4Phantom - Saturday, Oct 08, 2005 at 09:10
75 a/h is a lot for a normal charger to charge, it will take ages. As a rule of thumb, the longer a battery takes to charge, the better condition it is in becuause it is accepting more charge. I have had 4amp chargers take more than overnight to fill a large battery in good condition. One more thing, if the battery is stuffed it may never get to the voltage the charger is set to cut off at say 14v. This means the charger will never stop, i had a battery left to charge over a weekend in a factory fill the whole place with hydrogen gas, bubble the battery to bits and almost knock us out on the way in monday morning. This is becuase the battery was damaged, and the charger just kept filling it up.
AnswerID: 133605
Reply By: dags666 - Saturday, Oct 08, 2005 at 10:49
hi mark do a lot of beach camping with deep cycle batteries and found the best way to gauge batteries is with a muti meter you will get a spot on read no mistakes 11.5 dead flat 13 to 13.5 fully charged depending on how good your battery is . buy a good cheap muti meter one from tandy or dick smith or even super cheap auto.but a good one will last you forever. dags
AnswerID: 133617
Follow Up By: Sand Man (SA) - Monday, Oct 10, 2005 at 09:56
dags,
Can't agree with you on your figures.
11.5 volts equates to about 20% remaining.
10.5 volts is dead flat.
Bill
FollowupID: 388015
Reply By: OMN - Saturday, Oct 08, 2005 at 17:12
thanks for the responses,
my battery charger is only 4 amps so didnt seem to have the grunt, went to Bunnigns and there chargers same size as mine were not rated to charge a 75Ah battery. This was the same brand as mine, but a few years newer.
Borrowed my mates charger that can go all the way to 7 amps and it seems to have charged it up pretty quick.
Am currently runnign the fridges to see how long it lasts to get an idea of whether the battery is stuffed or not.
Then i will recharge it again.
Mark
AnswerID: 133652
Reply By: OLDMAGPIE - Saturday, Oct 08, 2005 at 22:10
omn
i have had a brand new 75a/h deep cycle for several weeks went for a trip checked the battery every morning after use [ fridge etc] sometimes down to 12v , 11.8, 11.4 after recharging from alternator went to 13.4v every time (exide) hope this helps
AnswerID: 133692
Reply By: V8troopie - Sunday, Oct 09, 2005 at 01:35
Mark, if the battery was at 11.1V for any length of time before you started charging it it is truly dead. Yes, it would take ages to charge and you may be able to resurrect it, it also may need desulphation before it regains a decent capacity.
You really won't know its present charge state until you take it off the charger, let it first rest over night then connect the 12V fridge or a light, then measure at the terminals. If it measures 12.6V it has come good.
Do youself a favour and NEVER let deep cycle batteries drop below 12V before recharging, they will reward you with a much longer life.
Klaus
AnswerID: 133719
