Triton '97 wheel bearing gears up
Submitted: Saturday, Oct 08, 2005 at 17:15
AdelaideGeorge
Re my post 27049;
I am having trouble getting the circlip back in the groove - as i try to get it into the groove in the spined shaft, the shaft moves rearwards (towards the diff) and makes the seating of the circlip impossible. Anyone remeber having a problem a problem of is sort?
The circlip doesn't have holes in to allow circlip pliers and it's a devil of a job!
R
george
Reply By: HJ60-2H - Saturday, Oct 08, 2005 at 17:21
The shaft likely has a hole in it's centre to allow you to screw in a bolt, 8mm? Use this to pull it out and hold it out. The clip you are putting on is best done with the proper pliers, not C clip pliers as you have foud out! I have put these clips on before using long nose pliers. Good luck!
133657
Reply By: Russel & Mary - Saturday, Oct 08, 2005 at 17:45
That's a nasty stutter youv'e got George, and it sounds like youv'e got a cold as
well. Rus.
133660
