1998 jackaroo td 3.0l intermittent engine fault
Submitted: Saturday, Oct 08, 2005 at 17:29
joer
hi we're at a bit of a loose end and hope somebody can help, our jackaroo has several symtoms 1. after starting the engine has refused to accelerate past idle 2. it has on several occasions just died whilst being driven it will then usally restart and drive normally 3. on several occasions after starting has run like a hairy goat. The techs in our small country town in northern nsw are at present replacing the wiring loom to the injectors but they are not confident this will fix the problem, does anyone have any suggestions or can they recommend a tech with experience in these vehicles somewhere in our area or maybe sthn QLD
Reply By: Moz - Saturday, Oct 08, 2005 at 21:04
G'day joer,
These engines are drive-by-wire, meaning they have a small
electric motor operating the throttle. It sounds like this or the
wiring to it is playing up. Have they checked this out?
They have been known to have problem ploblems with the
throttle body.
Cheers Moz
133680
Reply By: joer - Saturday, Oct 08, 2005 at 22:33
thanks for your reply moz do you think that could be responcible for the engine just dying as
well joer
133697
Reply By: cmilton54 - Sunday, Oct 09, 2005 at 18:46
hi Joer
Mate has same, about 2001 i think. Took over 9 weeks to finally sort problem. It was on going for nearly two years. eventually put in older model computer setup to fix. Email me and i will see if he will email you his phone number for you to call him. Or see if your tech can ring the local dealer in
Kimba SA
Charlie
Had 2002 model same but quit it and got a 3.0ltr Prado because of his problems with his.
133782
Reply By: joer - Sunday, Oct 09, 2005 at 19:08
thanks for the reply charlie my email is jlreilly@aapt.net.au ph 0266322772 mob 0427005864
133786
