Canning stock route - how much fuel do i carry
Submitted: Thursday, Dec 26, 2002 at 01:00
sean
I am conemplating the canning next year during the dry.
I have read that fuel can be arranged along the way but how much fuel do I need between fuel stops.
Trek notes on this site states 400 to 470 litres of diesel for whole trip.
My tanks only hold 125 litres in total so do I need to carry extra and what is the longest distance with no fuel.
thanks
Sean
Reply By: ExplorOz Team - David - Thursday, Dec 26, 2002 at 01:00
Sean,
As per the other details in the trek notes stating:
"Must be able to carry equivalent fuel for 1185km (factoring in heavy sand travel ie high fuel consumption)." This indicates that the longest section is 1185km as the fuel availability at the community is not guaranteed in any way, in any case this only brings the requirement down by a coupe of hundred km's.
We are going to do the Canning this year as our research trip and in our 80 Series Diesel we will be taking 300+ litres of fuel on board. 160 + 90 in our tanks + 3 x 20 litre jerry cans. If you vehicle only holds 125 litres then you will need to be carrying at least 8 20 litre jerry cans (I would not be leaving with less, some may). There can be hundreds of reasons to ensure that you are carrying enough (ask the German tourist that got stuck out there for 5 days between cars comming past in 2002).
Last year we did a trial trip across the Anne Beadell Hwy and this was about 1300kms between fuel and we took the same 300 litres and had about 60 left when we hit
Coober Pedy. The Anne Beadell does not have as many dune crossings and side diversions as the Canning so we expect that we should be fine with our 300 odd litres for our 6cyl diesel ensuring that we arrange a fuel drop at
well 23 of the standard 200 litres (44 Gal Drum). You must at least be able to take this 200 litres onboard, so I guess I am saying that if you can only carry 125 litres then I suggest that you start so very serious planning about fuel and food capacity for a trip of about 3 weeks duration without supplies and fuel for around 1200kms.
All the best and good luck.
David
10187
Reply By: Tony - Thursday, Dec 26, 2002 at 01:00
Sean you haven't said what type of vehicle you will be travelling in, and what end you will be starting from.
In a HJ 47 Troopcarrier a couple of years ago, starting from the north end I used 160lt by the time I reached
Well 23 (fuel dump) I carried 240, so had a bit in reserve. Now remember
Well 23 is about 1/2 way.
Tony.
10190
Reply By: sean - Friday, Dec 27, 2002 at 01:00
Thanks guys. I knew the distance but that does not tell me how much fuel I will need as that varies due to how hard the going is.
Mine is a Nissan 3.0 l diesel and I find that 7 km/litre is 'normal' so 300 litres sounds like a very comfortable margin and 240 litres sounds ok if all goes
I am a 'risk adverse' sort of guy so will err on the comfortable side.
We will be starting from the north (we live in
Darwin). Not sure which way we will take to get back up north.
Next questions is - where do I carry all that fuel.
Sean
10198
Reply By: brian - Friday, Dec 27, 2002 at 01:00
Hello sean, sugest you look up www.4wd.net.au should get some usefull info from vic widmans double crossing of aust.fuel consumption figs and repairs encountered could be of interest. i may be wrong but i wouldnt expect your figure of 7k per litre to be normal for a heavilly loaded patrol in 4wd conditions,but good luck and happy travelling.
10202
Reply By: Tim Nivo - Saturday, Dec 28, 2002 at 01:00
Sean. I travelled the csr this year solo in late september early october, in a gu 4.2 turbo ute. After doing all my calculations, I left
Wiluna with 235 litres of diesil and an empty jerry can(175l in tanks, 60l in jerrys). Left
well 23 with 255 litres on board and made it to
halls creek. Did side trips to
calvert range and separation
well. It was very warm in the middle of the day and used the aircon quite a bit. Backup plan was to first forget the side trips, then go for top-ups at
well 33 Kunawaritji and/or billiluna. Its the age old question of weight versus range versus risk. I personally would have no qualms about going again carrying only 235 litres, and perhaps even less if phone calls told me fuel was available at 33 and billiluna. Consumption and range was calculated on 20l per 100km. Experience has shown me this is the maximum fuel used by this vehicle in hot sandy conditions, but always averages less because of flatter, easier sections that exist in
the desert. I hope this helps a bit, and have a great trip. Tim Nivo.
10251
Follow Up By: Sean - Saturday, Dec 28, 2002 at 01:00
Thanks Tim, thats the best infor I have had to date.
I agree that plannng on 5km per litre is the way to go. I get 7km per litre in just about all conditoins from highway at 120 to pushing through thick bulldust at 50km/h in 4WD for 100km continual. Economy drops in slow going and when towing on highway. We will be going from north to south. Where did u carry the extra fuel.
Sean
5366
Just re-read your post - of course you carried the fuel in the tray.
Your were a 'little' brave were you not leaving your run into early october. It gets hot and it does rain at that time of year. Thanks again........
Sean
5367
Reply By: brian - Saturday, Dec 28, 2002 at 01:00
Sean,please note the fuel consumption quoted in previos reply,20 litrs
/100 klm equals 5 klm per litre,this confirms your expectations could be out by approx 40 %
10254
Reply By: Member - Jim - Sunday, Dec 29, 2002 at 01:00
Sean
Tim Nivo's reply is spot on.
I did it a couple of years ago towing a camper trailer and used pretty much the same amount of fuel.
I had a Landcruiser 2h turbo.
Have a great trip
Jim
10277
Reply By: Member - Willem- Sunday, Dec 29, 2002 at 01:00
Sean, It is much harder doing a north/south trip. Because the dunes run to an angle across the track you have to aproach each dune crossing via a left hand bend. Sometimes you do not have the momentum to run up the dune and have to reverse and try again. ( and again, and again and again...)
Admittedly we did the Canning in an ageing Landcruiser FJ55 Petrol. We used 340 litres to
Well 23 from Bililuna which included and extra 180km return trip to
Helena Spring from
Well 41. On that side jaunt on the way back, it took 7 goes to get over the highest dune in
the desert, with tyres at 15psi !! We arrived at
Well 23 with 9 litres left in the
tank. That is cutting it a bit too fine. Rule of thumb is to estimate your fuel consumption and then double it. Now carry enough fuel for the revised estimate. Have fun. Cheers, Willie
10298
Follow Up By: Sean - Monday, Dec 30, 2002 at 01:00
Willem
North to South being harder is something I did not know. Thanks - it is very useful information. I can just as easily go South to North cos I have to get to the other end one way or the other. I was thinking of doing a loop that includes the
Great Central Road.
Ssean
5405
Willem
Great Central Road.
Sean
5406
