Winch Basttery
Submitted: Tuesday, Oct 11, 2005 at 15:42
Vince NSW
Just been down to Repco to spend the ?HUSH? Money they gave me when I couldn?t buy one of the $99 DVD?s. My wife, God bless her, has been worried about the effort I have to put into the hand winch and has MADE me buy an electric winch. I might add that I have only used the hand winch twice in 3 years, 7 only one of those times was in anger. Anyway I picked up a 9,500 lb winch for $499 less the $100 hush money, so it was the same price as a cheap hand winch.
The question. What size battery should I put in to run it ??
Have a 760 CCA cranking battery that it would be running from. Is this Big enough ? Bearing in mind that this thing may be used every blue moon, but I will want it to work when it?s needed.
Vince
Reply By: sudsy - Tuesday, Oct 11, 2005 at 15:48
Should be fine.
Just run the engine slightly above idle when winching to keep some charge up to the battery
134133
Reply By: flappa - Tuesday, Oct 11, 2005 at 15:49
Its running off a dual battery is it ?
134134
Reply By: andrewr - Tuesday, Oct 11, 2005 at 16:10
My winch is 9500 lb also and the manual it came with recommends a battery of at least 650 CCA, so 760 is probably enough.
134139
Reply By: Vince NSW - Tuesday, Oct 11, 2005 at 16:16
Thanks Sudsy & andrew.
Flappa, I do have a dual battery system, BUT, the second battery is a deep cycle for the fridge & I thought it may not be a good idea to use it for the winch so would run it via the cranking battery, I realise that the motor would have to be kept running as the cranking battery will flaten quickly. Any info will be greatfuly received
Vince
134140
Follow Up By: Voxson (Adelaide) - Tuesday, Oct 11, 2005 at 16:25
Not so good to run a winch from a deep cycle....
388225
Follow Up By: flappa - Wednesday, Oct 12, 2005 at 13:41
Couple of thoughts.
Most of the guys I know that run dual batts and a winch use 2 large crank batteries , and also run their fridge off the Aux Battery.
Problem with running your winch off your main batt is IF you cant have the vehicle running , you are likely only to get a few minutes out of the winch , and your DC may or may not start your vehicle.
Running it off the Aux Cranking Battery , then you have no problems with what your main battery is doing , and if you CAN keep the motor running . . . bonus.
Just fuel for thought
388385
Reply By: Zapper - Tuesday, Oct 11, 2005 at 16:57
Hi Vince
How does the winch look? Like does it look reasonable quality?
134146
Follow Up By: Vince NSW - Tuesday, Oct 11, 2005 at 17:22
Yes looks good & 3 year warranty.
I know you get what you pay for, but the price of the gear comming out of Chian, I don't think you can go past. If it only has half the life of an expensive one I'm still ahead.
I have tried buying Australian made all my life, but I have grown old grummpy and turned into a cynic.
388234
Reply By: Member -Dodger - Tuesday, Oct 11, 2005 at 17:22
Vince, your cranking battery will handle it easily and at 9500lbs the winch will also handle the Frontera easily. As said previously if your vehicle has a hand throttle keep the engine about 2000 revs so the alternator will help with power.
Looks like you got youself a bargain.
Er happy pulling.
134148
Reply By: Pilbara Wayne - Tuesday, Oct 11, 2005 at 17:35
Repco winch for $499? Here in WA they're advertised at $699. Wonder why there is such a big price difference.
134151
Follow Up By: GOB & denny vic member - Tuesday, Oct 11, 2005 at 17:41
repco will probably tell you its the fuel costs across the nullabor ?????
lololol
steve
388236
Reply By: Redeye - Tuesday, Oct 11, 2005 at 18:32
Wow $499, Where dd you get it ?
I payed $699 for
mine.
Also noted that there was an "*" on the 3 year warranty saying conditions apply. But I could not find any of the conditions.
Redeye
134155
Reply By: Vince NSW - Wednesday, Oct 12, 2005 at 11:02
After the above posta re the price, I checked the Repco Dogalog and rang the local store. "Yes sir the price for the 9500 lb winch is $699." "Don't uou have one for $499" "Yes sir but that is only a 6000 lb"
Vince races out side to check. It's a 9500 lb so the bargain I thought I got was now MUCH bette.
There may be such a thing as Kama !
vince
134283
