Engineer Inspection - Further to post 27198
Submitted: Tuesday, Oct 11, 2005 at 22:12
ThreadID: 27198 Views:3533 Replies:3 FollowUps:2
What the Engineer did in post 27198.
Pop Top Camper Conversion
(1) Full inspection of the vehicle including checking every ‘mother’ of a identification number against compliance plates, purchase and rego papers a zillion times.
(2) Inspected modifications for structural compliance.
(3) Checked Electrical Certificate.
Note: it had a gas fitting (Bottles plumbed to inside stove) however I had to take it all out as it did not comply with current requirements of two open vents, approx 300mmx200mm either in the floor or the walls at floor level, and a monster hole/vent in the ceiling constantly ventilated.
I chose not to ventilate my rig for gas purposes , thus letting in dust, water and general C H I T.
(5) Photographed everything he checked.
Suspension:
(1) Inspected it (Shocks, spring packs, Shackles, Poly-air bellows, bushes)
(2) Photographed it all from a number of angles
(3) Noted Manufacturer spec stickers for later confirmation purposes.
(4) Checked tyres specs against OEM tyre sticker specs
GVM
(1) I had to load it, (full fuel, water and everything else you normally have in it on a trip except clothing) then take it to a public weigh bridge and have a
‘split weigh-in’. That’s where they do the front axle by itself, then the whole vehicle. The rear axle weight is then obtained by subtracting the front axle weight from the total body weight. RESULT: 3200KG
Note: apparently a lot of vehicles fail at thi point by exceeding the allowable front axle weight.
(2) The vehicle was then ballasted up to the max GVM allowed (in this case 3500kgs) by adding both mine and the engineers body weight, and drums of water.
(3) I then had to drive it to a local hill which is VICROADS surveyed approved hill of no less than 12degrees incline. (felt like a 132 degrees. The poxing drums of water slid down the back it was so steep)
(4) Near the top of the subject hill vehicle was halted, placed in neutral, engine left running, hand brake on, foot off the brake. (Vehicle then photographed in this position.
(5) The vehicle was then turned around and halted on the opposite of the road and the same test done.
Note: this is the second fail point for a lot of vehicles.
(6) Electronic technology including laptop computer then affixed to vehicle and brake tests carried out.
(7) Two passes (one each way) to test brake fade at 100kph
(8) Front brakes isolated (Cut off) and rears tested for Brake fade at 100kph – two passes
(9) Rear brakes isolated (same test as above) (F****** scary stuff trying to pull up 3500kgs on front brakes only.
Note: You have to achieve the minimum/plus allowable rating on both passes. There is no averaging or taking you ‘best shot’ so to speak.
(10) issued and applied new Tyre spec sticker (bigger ones)
Advised that vehicle now complied with current regs for the three areas of change, and that a certificate and compliance plate would be issued re same.
Reply By: Member - 'Lucy' - Tuesday, Oct 11, 2005 at 22:13
Oops! should read - Post 27191
AnswerID: 134213
Reply By: Haza - Tuesday, Oct 11, 2005 at 22:17
Geez, how much did that set you back?
AnswerID: 134217
Follow Up By: Member - 'Lucy' - Tuesday, Oct 11, 2005 at 22:36
I posted in post 27198 that it cost $660 for the engineer, however I forgot to add the cost of the weigh bridge ($12) and a current electrical certificate ($120)
So, round it up as $800.00
The engineer didn't have to do any structural testing/computations on any of the mods/additions.
All he had to do was inspect it, obtain identification details for everything and then cross check it with manufacturers specs and/or previous engineered items.
The brake tests was the only area that he had to undertake a 'hands on' on the road field type regime (3 and 1/2 hours for that bit).
FollowupID: 388298
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Oct 12, 2005 at 02:36
I was lead to believe my ex camper only had to go over the pits to get registered as i talked to the guy who gave it the roadworthy and it was significantly more modified than yours - total rebuld from the cab back including the roof and all the drive motor g box and diffs etc were out of an earlier model. Only problem I had was that no mainstrea insurance company would insure it coz it was custom built
AnswerID: 134239
Follow Up By: Member - 'Lucy' - Wednesday, Oct 12, 2005 at 08:50
Morning Davoe.
The aforementioned is what is required in Victoria.
I am willing to put up $50 that it is similar in all other states if you have changed your vehicle from the OEM engineered specs.
i.e. Altered from compliance plate ratings, type sticker specs and any structural alterations.
Must admit that when I was advised by VICROADS in the first instance as to what I had to do, I literally 'died in the a r s e'.
However it was all that bad in the long run. Just a lot of organising and running around.
FollowupID: 388357
