75series ride
Submitted: Wednesday, Oct 12, 2005 at 20:24
ThreadID: 27222 Views:1611 Replies:2 FollowUps:0
Hi,have a 75series with 750 16 dunlops wife think the ride is to harsh would wide rims with all ter improve it .Regard Bat.
Reply By: Exploder - Wednesday, Oct 12, 2005 at 20:33
With leaf springs all round the ride will never be anything to Wright home about.
Bigger tyres running at slightly reduced pressure will help a-bit say 30-35psi instead of 40 just as a example, but then you will wear the tyres out faster.
AnswerID: 134358
Reply By: snailbait (Blue mntns) - Wednesday, Oct 12, 2005 at 21:41
Hi BAT
Please have alook at the tyres are they Radial 750 160 or cros plys you do not advise what the side walls are they could be 6 8 10 ply or equiv the high in ply rating will give a harsh ride
also if you have the vehicle tyres pump up to 50 lbs this will give a harsh ride also
do you carry any weight on the tray if it is no weight and the springs are leaf springs
inspect the springs to see if they have saged
now look if the large flat spring at the bottem near the axle has the others springs resting on this spring if it has you should have the springs Reset this should give you a much softer ride and with a lower pressure when you have a empty tray a softer ride on the new or old 75 series
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
AnswerID: 134386
