lc100 live axle coils
Submitted: Thursday, Oct 13, 2005 at 19:45
ThreadID: 27240 Views:2884 Replies:4 FollowUps:2
i want to lift my lc 100 live axle petrol 2 inches. i believe that new shockies are not needed nor is damper.
prices to get a 2 in lift are abb 1800, tjm 1200, buy 4 coils fitted 410
4 coils fitted by tjm 500
am i correct in only fitting the coils .car has done 80000, includes 2 cape york trips.
and any comments on quality of different coil manufactures eg tjm are king spirngs
thanks for any help and advice
fred
Reply By: 120scruiser - Thursday, Oct 13, 2005 at 20:46
Fit King Spring medium raised coils.
Part numbers KTFR69 KTRR70
Fit some air bags to the rear for load carrying.
Leave the standard toyota shocks as they are good.
I have just done an Flinders, Ayres Rock, Alice, Simpson Desert trip on standard Toyota shocks with no problems in my prado.
AnswerID: 134532
Reply By: Ken - Thursday, Oct 13, 2005 at 20:49
Fredd,
In my opinion you should not just fit the coils. The 2" lift by the springs will mean you have 2" less on the down stroke of the shocks. Stands to reason , you lift the chassis & body up 2" there is 2" less for the shock to travel down when the suspension drops.
The other thing to consider is that it is the shocker that limits the downward wheel travel. If you lift everything 2" there will be that amount less downward travel and you are likely to end up with worse performance in the rough stuff due to the reduced suspension travel !
It pays to get good advice from a trustworthy suspension supplier when making these sorts of changes. If the springs and shocks are mismatched you risk reducing wheel travel or worse if the shocks have too much travel the springs can pop out. [unless spring retainers are fitted]
I have had only King springs and Konis on my vehicles on advice from people I trust and have been very happy, can't comment on others. Not cheap but less than $1800 for my current GU.
Ken
AnswerID: 134533
Follow Up By: Crackles - Thursday, Oct 13, 2005 at 23:10
If you fit a 2" lift & don't change your shocks or bump stops then the wheel travel distance will be exactly the same, the only difference being you'll have 2" less drop & 2" more compression. As long as the springs aren't too hard you wont lose any travel at all.
Although many people have had good reliability with using just the standard shock absorbers, it's far better to match new shocks with the new springs to ensure proper road holding & increased wheel travel particually seeing yours have done 80K & would be on the way out anyway.
Koni & Bilstien would be the pick of the shocks for reliability & performance offroad.
Cheers Craig.............
FollowupID: 388592
Follow Up By: 120scruiser - Saturday, Oct 15, 2005 at 13:46
You will find in a 100 series Ken it is not the shock that limits the travel but the sway bar. Yes shocks do limit travel but not in Landcruisers.
Thankyou for your comments crackles. 100 percent right.
FollowupID: 388759
Reply By: V8Diesel - Friday, Oct 14, 2005 at 09:36
I've got Kings, Koni's and Polyairs on my 100 Series and it is a pleasure to drive both on and off road.
AnswerID: 134582
Reply By: rod2101 - Tuesday, Oct 18, 2005 at 12:02
lovell tfr-44, trr-47 2" lift springs $127 a pair use orig shocks result firm but good in corners and works well off road (lc100 rfs). $250 for 4 springs! give them a go
AnswerID: 135032
