Follow Ups
Submitted: Saturday, Oct 15, 2005 at 12:52
ThreadID: 27278 Views:3456 Replies:3 FollowUps:2
The reversing camera and screen have performed very well. 43c heat of the Simpson Desert the corrugations, dust and rain of the last 6 months have not effected the performance of this system. The camera is mounted on the back of the roof rack and the screen is mounted on the overhead console. The screen does vibrates with the corrugations but the picture is clear and easy to see. I have the screen on when ever I drive so that it is not unusual for it to be on for 10hours.
This has been such a good investment and would recommend the system to anyone who does not have a clear view out of there vehicle.
Coming back from Tibooburra to Broken Hill a couple of weeks ago it was raining. The Silver City Hwy has sections of clay and bitumen, and when we stopped at Packsaddle for a break, no one could see out the back of there vehicles because of the mud on the rear screen. However I still had a clear view via the camera, so the vehicle does not have to be packed to the rafters before the camera is needed.
I have no connections or interests with the reversing camera distributor ect. ect.
Coopers STT tyres.
I was given a set (6) 285x75x16 tyres on the 1st of April. I was to test the tyres and report back to Coopers on how they performed.
Since April I have done 35000km, including the Vic High Country, Canning Stock Route, Flinders, Simpson Desert, and a lot of black top driving with a 50km round trip to work.
The wear rate at first was very high, 3mm/ 6000km, however the next 3mm has taken 29000km to wear. This is on the front tyres which have not been rotated. The rear tyres have been rotated in pairs and both pairs have been worn down to 8.5mm tread depth. There has been very little chipping of the tread block, but after the Simpson Desert crossing the rear tyre look as if the tyres have been hit with a big meat tenderiser.
I have not had any problems with grip on the dirt or sand, but they feel to me on the Troopie that they are a bit skidish in the wet going around corners. I have changed my driving habits when in the wet so I feel that this is not a big issue.
The Troopie is very heavy at all times and the suspension is very stiff so I would think that the wear rate would be higher than other vehicles which are lighter. I run 38psi most of the time and drop it down to 34psi on the dirt and 18psi in the sand. These tyre pressure are a guide for me as I will adjust them to suit the conditions on the day. So far I have not a puncture and the tyres have not felt out of balance, even though they did take a lot of weight when they were first fitted.
Would I fit them again?
After yrs running BF G's on the 80Series and having a good run with them and then asked to try the Coopers I was a bit negative to wards them. At this stage I am tending to go for the Coopers, but will have a better idea when they are due to be changed. That way I will see how many kilometres I will get out them and if I get a puncture.
What I have said here is the same as what I have told Coopers, they said the high wear rate was due to the tyres were green. I would go along with this as the wear rate has dropped a lot since the tyres first went on. I will say again that the tyres were given to me to try and to give an assessment of the tyres. I hope this does not appear to be bias but I have been honest in what I have found and the wear rate.
This is my opinion and findings and they might differ from other users of Coopers Tyres.
Wayne
Reply By: Paul - OzRoamer Camper Trailer - Saturday, Oct 15, 2005 at 19:46
good report big fella.
AnswerID: 134744
Reply By: Eric from Cape York Connections - Sunday, Oct 16, 2005 at 07:29
Hi wayne you say they have been hit by a meat clever is that chipped or stuffed or what.
All the best
Eric
AnswerID: 134773
Follow Up By: Wayne (NSW) - Sunday, Oct 16, 2005 at 09:49
Eric,
The tread blocks are still good on the edges but the top of the blocks have small holes in them. Photos to come soon.
Wayne
FollowupID: 388799
Reply By: Member - Roachie (SA) - Sunday, Oct 16, 2005 at 09:09
Thanks for that report Wayne,
I have similar experiences with my Poron reversing camera as what you have described. A very useful bit of gear. I have, on occasions, noticed the screen is "snowy" on initial switch-on, but that always corrects itself after a minute or 2 and probably only occurs once in every 20 turn-ons anyway...not a big issue.
I also leave mine on all the time when driving although I have been told by a copper (on a talk-back ABC radio segment a month or so ago) that this is technically illegal, cos you're not allowed to have a VDU operating where the driver can see it whilst he is driving. He also reckons I broke a ADR rule by removing the internal mirror in order to fit the screen where the mirror would normally be located. Too bad; it's so useful that it's staying and I'd love to see what a court would say if it ever got to that stage (although common sense IS dead and buried, so I'd probably get flogged by a judge).
The Coopers STT certainly look the goods and sounds like you're getting a good run with them. I went with the MT/Rs cos I was disappointed with my STs. So far the MT/Rs are doing very good for me.
See ya mate
AnswerID: 134783
Follow Up By: Wayne (NSW) - Sunday, Oct 16, 2005 at 10:23
Roachie,
It has been a while, and I have spent so much time in South Australia in the past 12 months that I fell I should follow AFL, but that is another story.
As far as the removal of the internal mirror is concern is that as long as you have 2 wing mirrors you are ok. The vision out of the back of the vehicle may be blocked by a van being towed or canopy or some form of special body fitted to the vehicle.
In the case of my Troopie, being an ambulance it would have had a lot of stuff in the back and the rear windows are very heavy tinted so the internal mirror is not used.
Just after I had the camera fitted I was in Port Augusta and two coppers were parked next to me in a car park. One of them came over and was asking me all about the camera and screen and he wished they had them on there police vehicles as they are very hard to see out of the back.
I have noticed the trend in top of the range vehicles and Pajeros, that a screen is located in the dash in clear view of the driver. On this screen it may have a lot of information like a moving map. I can't see the difference at looking at a map and checking what vehicle is behind you.
Hey mate, going by the sign off signature at the bottom of the post you need to get out more.
Wayne
FollowupID: 388801
