STT 35000km latter
Submitted: Sunday, Oct 16, 2005 at 12:08
Wayne (NSW)
!MPG:8!
This front tyre has been on since new and has gone from 15mm to 9mm depth of tread.
The next 5 shots are of the rear tyres that have been rotated in pairs and have shared the 35000km
!MPG:9!
!MPG:10!
!MPG:11!
!MPG:12!
!MPG:13!
Reply By: Outback Rick - Sunday, Oct 16, 2005 at 12:49
Wayne,
Could you tell us hopw many km on dirt/stones/gibbers/ etc?
Have you driven in country where you could really test the sidewall strength & resistance to pusticks, stones etc ?
Are you a happy traveller with:
- this km response?
- this degree of chips/cuts/abrasions etc
What vehicle & weight do dou pilot?
134802
Follow Up By: Outback Rick - Sunday, Oct 16, 2005 at 12:57
Sorry for the poor typing skills:
test the sidewall strength & resistance to pusticks, stones etc ? - should be .............................BUSH & STICKS !
What vehicle & weight do Duo pilot - should be ..............Do YOU pilot
Could you tell us hopw many km - should be.................... HOW
388809
Follow Up By: Member - Geoff M (Newcastle) - Sunday, Oct 16, 2005 at 13:25
Outback Rick,
Have a look at Post ID: 27278, Wayne actually mentions some of the technical stuff in there you are asking about the tyres.
Geoff.
| Geoff,
388810
Follow Up By: Wayne (NSW) - Sunday, Oct 16, 2005 at 13:43
Rick,
Living in the
Sydney area and doing a lot of the trips in another states there is a lot of blacktop driving.
It would be hard to put a figure on the ratio between blacktop and dirt but I would have a guess and say 60% blacktop 40% dirt
The trips that I do now are mostly touring rather than rock crawling.
The most damaging road would have to be from
Birdsville to
Innamincka via Arrabury and
the Dig Tree.
Other tracks/roads that they have been on are The
Great Central Road, The
Canning Stock Route, The Tamami Track, The
Oodnadatta Track, the Strzelecki and a lot of the tracks around the Victoria High Country
The Troopie would have to weigh in at 3t just going to and from work and up to 4.5t when going on a trip.
So far the tyres are 6 months old and have done 35000km and I should get another 35000km out of them.
I placed a post titled "Follow Ups" and there I give a report on what I think of the tyres.
Wayne
388813
Reply By: Willem - Sunday, Oct 16, 2005 at 17:55
Hi Wayne
Your tyres seem to be doing a bit better than
mine.
Mine are the earlier model STT's. I have done 20,000km and tread is down to 10mm. About 90% of wear was on dirt roads and one hard, rocky stretch, along the cliffs of the
Great Australian Bight. I change the tyres around every 5000km.
My tyres have cuts in between the lugs, severe scuff marks on the sidewalls and one or two lugs badly cut and ready to fall off. On one tyre the inside ply has separated and my tyreman has put a gater in. It is on the spare.
I have had no punctures out bush but seem to pick up nails at random around town.
Not sure if I will go with Coopers again.
134820
Follow Up By: Wayne (NSW) - Sunday, Oct 16, 2005 at 18:52
Willem,
I would like to put it down to the fact that the way I drive the Troopie is easy on tyres but is more likely be the difference between the old and new.
When they finally wear out will be the big test on how good they are and whether they are worth putting back on again.
The next 6 months should also give them a good work out as I will be doing a lot of trips in the Victorian High Country.
If they last 12 months, I will be happy with them. With the BFG's I was only getting 12 months before I replaced them. This was due to the greater risk of getting a puncture when the tread blocks wore down.
Wayne
388832
Reply By: Bob of KAOS - Wednesday, Oct 19, 2005 at 05:00
Wayne
how did you post the pictures?
135170
Follow Up By: Wayne (NSW) - Wednesday, Oct 19, 2005 at 06:06
Bob,
To post the photos,
1. Down load the photo to the computer
2. Reduce the size of the photo to no more than 50KB. That is the hard bit. I have found it better to take the photo on a camera with a low pixel rating.
3. Click on "My Home" top right of page
4. When this comes up scroll down to the bottom of th page and there is a section to down load 6 photos
You have a photo in your signature at the end of a post so you know how to get this far.
5. At the bottom of the page when you make a new post there is a line that has "Members Add Gallery Picture" Click on this and follow the links.
6.You use the photos from here to add to the post.
David did have a post on how to do it but it was some time ago. If you still have a problem email David or the EO team and they should be able to help.
Wayne
389095
Follow Up By: Redback - Wednesday, Oct 19, 2005 at 08:33
a href="">link text at either end and thats a link to your web page much better and they see much more.
Baz.
389113
Follow Up By: Bob of KAOS - Saturday, Oct 22, 2005 at 11:49
Many thanks Wayne
389618
