Tyre pressure for black top: who to believe?
Submitted: Tuesday, Oct 18, 2005 at 10:50
ThreadID: 27344 Views:6609 Replies:13 FollowUps:7
Everytime I get the car serviced or the tyres rotated, they check the tyre pressure and put more in than what is recommended by the car manufacturer (and I have the original tyres on). On Saturday I had a tyre rotation done and the bloke told me that the tyres should be at 36psi where the car manual stipulates 26psi ! When I checked the tyres at home after they had cooled down they were in fact at almost 40psi and the marking on the tyres themselves says max pressure 36psi! So who is right here?
Should I trust the manufacturer recommendation or put a higher pressure close to the tyre limit? Would that have any impact on how the car handles or on the wear of the tyres?
I am talking for road usage here of course.
Thanks,
SLY.
Reply By: Redback - Tuesday, Oct 18, 2005 at 10:52
The manufacturers recommendation.
AnswerID: 135014
Follow Up By: GaryInOz (Vic) - Tuesday, Oct 18, 2005 at 11:16
The car manufacturers reccomendation is usually more oriented to comfort ie, too soft.
Best bet is to go by the old 4 psi rule. Measure pressure cold, go for a drive long enough to get everything hot and immediately measure the pressure again. If the pressure difference is4 psi then increase the COLD pressure (corresponds to the sidewalls working too much, generating too much heat = underinflated).
As for how much to add/subtract, it's a bit of "suck it and see" but try 3-4 psi at a time until you get the 4 psi difference.
FollowupID: 388998
Reply By: Snowy 3.0iTD - Tuesday, Oct 18, 2005 at 11:07
As long as the tyres are the size and specification stated on the vehicles tyre placcard, then go with the manufacturers pressure recommendation every time, if you have different size/type tyres to what is on the placcard then talk to the tyre manufacturers technical department which can usually be found on the webiste, and a bit ot trial and error using the 4psi rule.
AnswerID: 135017
Reply By: flappa - Tuesday, Oct 18, 2005 at 11:09
I would disagree with that.
The Vehicle Manuafacturer isn't interested in tyre life. That is not their concern. The Tyre Manufacturer would be better for advice (and that DOESN'T mean , tyre shops/fitters).
26psi , would be good for vehicle handling as it allows the tyre to move , heat up , and get maximum grip, however , it also SEVERALLY effects the life of the tyre.
Its all about compromise.
A lot of us use what they call the 4 psi or Pirelli Rule.
The tyre should increase by a max of 4 psi between cold , and hot after a decent run of approx 15 mins.
In my case , in both my 4wds , between 36 and 38 psi gives that end result.
My tyres (BFG AT's) are all around 80,000 k's with a bit of life left in them.
AnswerID: 135018
Reply By: Member - Stan (VIC) - Tuesday, Oct 18, 2005 at 11:10
I always go at least 10 psi above the manufacturer recommendation. The reasons are:
1. You use less fuel
2. Your tyres last longer (less wear)
3. Can't remember the third one...
AnswerID: 135019
Follow Up By: Crackles - Tuesday, Oct 18, 2005 at 17:32
Stan, 10 psi more than factory recomendation can increase the braking distance, perform worse in the wet, corner poorly, increase likelyhood of getting a puncture & lessen traction. You are probably right that there will be some minor fuel savings but I doubt tyres will last noticably longer than a set at the correct preasure. I suppose it's a matter of weighing up if saving a few dollars on fuel & tyres is as important as road holding & safety. Cheers Craig...........
FollowupID: 389033
Reply By: squiz - Tuesday, Oct 18, 2005 at 11:14
If they are bridgestone 693's 30psi is plenty.
On a Patrol I use 30 front and 28 back. And
after travelling an hour down the hwy, they only go up about 1 or 2 psi.
So the 4psi rule says they could go down about 27.
Anyway I know 693 are not a true light truck construction tyre,
But I have had 40K of trouble free km on them. I don't trust them much on the gravel roads around hear anymore. But if I just used them on the hwy now I
might get another 10K out of them.
AnswerID: 135021
Reply By: Sand Man (SA) - Tuesday, Oct 18, 2005 at 11:15
None of them. They are only a guide.
The Manufacturer recommendation is a good starting point, but usually rated too low for good tyre wear or optimum performance. This pressure is optimised to give the "best ride" comfort wise on the blacktop and you could go up at least 4-6psi.
You are better off performing your own test using the 4psi rule.
Then YOU can tell the service people what YOU require.
Over a period of time, an under-inflated tyre will show abnormal wear on the outside edges of the tyre. An overinflated tyre will show the wear in the centre area of the tread as the tyre will tend to "balloon" out. This is probably the worst for grip as only the centre portion of the tyre will be touching the road surface.
Mate, if your tyres measured 40psi after they had cooled down they would have been running close to 44psi when hot. (Assuming the tyre gauge is accurate).
This sounds way too high.
Bill
AnswerID: 135022
Reply By: DustyM - Tuesday, Oct 18, 2005 at 12:13
Sly,
You have already received lots of good advice, above, but here's my 2 cents worth anyway:
1. Vehicle manufacturers will always recommend and placard tyre pressures at the lower end of the tyre manufacturer's recommended pressure range. Lower pressures allow greater sidewall flexibility, which in turn provides a softer ride and greater passenger comfort. Tyre wear doesn't really enter into a vehicle manufacturer's criteria when placarding tyre pressures.
2. On several occasions I have heard stories related by reputable race and rally drivers that increasing tyre pressure increases tyre performance and grip. In one such story, tyre pressures on a Commodore/Falcon-type sedan was increased successively in 5 psi increments, and the car then timed on a race circuit. Lap times continued to be reduced with each successive increase in tyre pressure, until something silly like 60psi was in each tyre. (These were normal road tyre, not racing tyres.) This suggests that tyre performance is enhanced by increasing the pressure. (Don't know how this relates to 4WD tyre performance).
3. Under-inflated tyres will suffer increased wear at the edges of the tread, thereby decreasing tyre life. Over-inflated tyres suffer increased wear at the middle of the tread, also reducing tyre life.
4. There is quite a large range of pressures over which a tyre will operate without compromising on performance (grip) or safety. I commonly run my tyres at 5-10psi above the vehicle manufacturer's placarded tyre pressures and am very happy with both the tyre performance and the tyre life that I achieve.
Hope this helps.
AnswerID: 135035
Reply By: Redback - Tuesday, Oct 18, 2005 at 13:46
All good advice but if you were in court and it meant going to goal, i know who's recomendation i would quote.
And it's comfort and handling for these pressures.
Ring Cooper tyres and ask them, i did when getting a warrenty replacement of their tyres, one of their question was what pressure was i running.
Baz.
AnswerID: 135048
Follow Up By: flappa - Tuesday, Oct 18, 2005 at 14:04
Yeah , the tyre manufacturer NOT the vehicle manufacturer.
The Tyre manufacturer would know what pressures to run for a given vehicle under certain circumstances.
The Vehicle manufacturer doesn't have that luxury. They cant predict what tyres go on what vehicle , they can only give a generic recommendation on the factory fitted tyre.
FollowupID: 389008
Follow Up By: Redback - Tuesday, Oct 18, 2005 at 14:48
Always Graeme, always.
FollowupID: 389012
Reply By: howesy - Tuesday, Oct 18, 2005 at 13:58
Find a wheel alignment dude that really knows his stuff and he can show you how to read the wear on a tyre to determine if the pressure is too low or not it is quite simple once shown. The tyre when underinflated for the driving condition rolls too far on to the edge of the tyre and shows in certain wear characteristics easily identified. My guess is that this is why the tyre service has looked at your tyres and said you need more pressue. I run 40 on the highway on just about all the brands and drop immediately i get on to dirt down to 24 to 30 and as far as 18 to 22 on rough 12 to 16 on sand all these being set at the start as the sand pressures after an hour or so will be considerably higher.
Everyone has their own preference but I never had less than 110000 out of any brand and never shredded any tyre even on ther cordillo to Birdsville so I must be reasonably close. ( reduced presures should not be run too far over 90kph for reliability)
AnswerID: 135049
Follow Up By: Sand Man (SA) - Tuesday, Oct 18, 2005 at 14:41
howesy,
Can't agree with your comments re reading tyre wear mate.
There are other variables, apart from inflation pressure that may affect uneven tyre wear.
Sure the Wheel Alignment shop would have valuable input because they can also check and eliminate toe-in/toe-out, camber & caster angles, the same as Suspension shops can determine if incorrect suspension components like bent axles, or steering arms, or buggered shocks, coils leaf springs, etc., are having an adverse impact, but that is way beyond the average Joe-bloe's know-how.
But merely checking tyre pressures and applying the 4psi rule (just once) will give the owner/driver the best indication of what pressure is best for the boots that the 4WD is wearing and the loading of the vehicle. This is far more accurate than the Vehicle Dealer, or Tyre Reseller, or Wheel Alignment shop can do.
I have found that I don't need to adjust pressures when going bush with my laden vehicle and camper trailer. The only criteria then is what surface I am on. THAT makes the only difference to whether I deflate/inflate pressures accordingly.
Bill
FollowupID: 389011
Follow Up By: howesy - Tuesday, Oct 18, 2005 at 15:51
like i said opinions vary and the wear from wheel alignment factors is different but like I said proof in the pudding no failures and 110000 to 170000kms across several brands and the vehicles have never seen a coopers so go figure.
The tyre pressure argument has been looming in forums for years and it really boils down to what you believe is right for you but I follow the advice of my local specialist who has been a front end specialist for 30 years and it works for me so what ever works for you , go for it.
FollowupID: 389023
Reply By: Exploder - Tuesday, Oct 18, 2005 at 18:56
26PSI, Hell I would not feel comfortable driving on the road with that pressure.
My tires sit on around 45-50PSI (cold inflation) temp when on the black stuff Cooper stamp say’s 50Psi cold temp.
Stay close to the tyre manufactures Pressure stamp and you will be fine, yes the ride will be harsher but tyres will hold the road much better and fuel economy will be better to.
With a max Cold inflation temp of 36 I would be inclined to run them at around the 32PSI or higher mark.
Having the tyres “sponge” around on the road will not give you good grip or handling it will make the car ride smoother and that is it. IMO
AnswerID: 135097
Reply By: cmilton54 - Tuesday, Oct 18, 2005 at 19:04
Everyone goes on about pressure. How many have EVER had thier gauges checked on a calibrated gauge for accuracy. Tyre gauges can very heaps, both low and high readings. I run 26 to 28 psi for normal running, (Pathfinder,jackaroo,triton and prado) up to 45 psi in triton`s fully loaded. With 18 foot poptop van still only run 28psi rear. All my trips north only normaly run 26-28 psi and drive to road conditions. Have our shop gauges checked twice year on calibrated gauge.
Charlie
AnswerID: 135101
Follow Up By: Muddy 'doe (SA) - Tuesday, Oct 18, 2005 at 19:15
Good point.
I have two gauges. The one on my compressor and then recheck it with a standalone hand held one. Have checked the handheld one against other peoples gauges and it is close enough for me.
Muddy
FollowupID: 389054
Reply By: slyonnet - Wednesday, Oct 19, 2005 at 13:54
Thanks for all the info guys. Lots of good advise. I'll try the 4psi rule and double check the pressure using my guauge and several others (friends and petrol station) to see if it's accurate.
Sly.
AnswerID: 135227
Reply By: madlee - Wednesday, Oct 19, 2005 at 20:37
Alot depends on the size of the tyre.As being a mechanic I monitor my customers tyre wear in relation to pressures.I normally put 36psi inthe front and 32psi in the rear for standard passanger cars.My own commodore with 235/45 17 tyres(low profile)I run 42psi front and 38psi rear and they still show signs of under inflation.I have a customer with a 96 80series Cruiser GXL on standard tyers,serviced every 5000km for 210000,tyre pressures,front-38psi,rear-34psi,perfect tyre wear.The thing is to find the right pressure to suit your car and driving style.A word of warning,I have seen cars that have just had tyres fitted at big name tyre shops and the pressures have been all over the place.All the best Peter.
AnswerID: 135326
