2ft6in mattress linen
Submitted: Tuesday, Oct 18, 2005 at 20:00
ThreadID: 27360 Views:1728 Replies:6 FollowUps:4
Can anyone direct me to a supplier of sheet sets for 2ft6in single mattresses?
I found a supplier of this size innnerspring mattresses to suit my poptop but I can't find the sheets to suit in Sydney.
I could get them made but the cost is likely to be much higher for tailor made.
Can anyone help?
Reply By: steve21 - Tuesday, Oct 18, 2005 at 21:22
have you tried tucking them under? maybe worth a go!
AnswerID: 135131
Follow Up By: Nudenut - Wednesday, Oct 19, 2005 at 11:10
why would you ant to tuck your sleeping bag under the mattress?
FollowupID: 389136
Follow Up By: steve21 - Wednesday, Oct 19, 2005 at 18:08
where is the mention of sleeping bag?
FollowupID: 389236
Follow Up By: Nudenut - Wednesday, Oct 19, 2005 at 18:11
you use real sheets?
FollowupID: 389237
Reply By: Jayk - Tuesday, Oct 18, 2005 at 22:37
Or you could get one that was heaps too big and just keep rotating it around to different sections. That way you could use it for yonks without having to wash it as much.
Why? ... Why not?
AnswerID: 135143
Reply By: Member - John C (QLD) - Wednesday, Oct 19, 2005 at 07:45
Sorry to say, we didn't have any luck for ours either.
Ended up getting a cheap 3' set and doing some mods with a sewing machine.
The mattress and sheets etc have since been tossed.
AnswerID: 135179
Reply By: OLDMAGPIE - Wednesday, Oct 19, 2005 at 09:59
whats a sheet?
AnswerID: 135193
he doesnt rough it i guess ?
FollowupID: 389135
Reply By: Member - Kingsley N (SA) - Wednesday, Oct 19, 2005 at 13:34
alandjane
You should make up lttle Suspender-like gizmos with accessories from "Spotlight" or similar haberdashery stores. You need one for each corner of the bottom fitted sheet (single bed size). There are similar items sold to hold ironing board covers snug. The fasteners are very similar to old fashioned ladies suspender snaps. Some are simply small spring loaded clamps with elastic in between.
I have not explained myself very clearly. You put the oversize sheet on and then place a fastener diagonally across each corner (on the underside). It works fine for us in the Coromal camper which has two odd sized mattresses. The top sheets just have to be tucked in normally. We use Doonas to throw over the top.
Kings
AnswerID: 135225
Reply By: Volante - Wednesday, Oct 19, 2005 at 15:21
we sewed on ties to the fitted sheets and used the 3' ones
the 4 ties are on the long side and tie together underneath
the ties work well as the sheets no longer ruffle up badly
AnswerID: 135244
