airbag susp. in GQ patrol lwb
Submitted: Friday, Oct 21, 2005 at 01:37
pizzle
can anyone please give me some info(pros&cons) with installing these
thanks
Reply By: Member - Roachie (SA) - Friday, Oct 21, 2005 at 07:45
Are you talking about FULL air bag
suspension to replace your coils? Or is it just the more-usual Polyair bags which fit inside the coils?
If it is the latter, then there are no "cons"......only "pros".
I've had my Polyairs in for about 150,000klm and had no worries at all. So long as you keep the required minimum psi of 5 in them at all times and don't exceed the maximum pressure of 30psi, you should have no worries.
If you're talking about the full airbag
suspension which does away with the coils, then I don't know anybody who has done this.
135515
Reply By: Member - Raymond - Friday, Oct 21, 2005 at 09:16
Hi Pizzle
I have a mate that changed his GQ to airbag
suspension, the first setup fail while up north and it took 3 weeks camped at
Cape Crawford to get the parts to repair the unit, failed again in
Darwin were they replaced it with coils and polyairs which worked fine.
Due to wanting full airbags so to be able take his slideon off easier had the unit rebuilt at Traralgon Vic. Needs an engineer cert, while polyairs or coilrite do not.
The advantage of air in coils is if the airbag fails you can still drive on using
the springs
Regards Ray
PS Polyairs on for 90000 with no problems
135527
Follow Up By: pizzle - Friday, Oct 21, 2005 at 14:42
thanks for your responses,sorry should have been more specific, asking about poly air(wasnt sure what they were called)
389499
Reply By: S&N - Saturday, Oct 22, 2005 at 22:43
you will lose articulation. but if you carry alot of stuff, they will be good. dont have them myself, friends doo, have been doing alot of reading on them.
135774
