Will this be suitable?
Submitted: Friday, Oct 21, 2005 at 08:49
sepp5762
We have a 2002 courier 2.5 td and want to put on it a slide on camper, the solid kind that looks like a small motor home when together not the tent kind. Our aim to take early retirement and travel for a few years while our health holds out.
The camper will weigh about 600kg unloaded. Some thoughts would be appreciated.
Reply By: simple - Friday, Oct 21, 2005 at 09:05
that sounds great. the 2.5td will be a bit slow on a
hill with it fully loaded, but you're in no hurry are you. you may need to put stronger
suspension on it.... maybe.
135526
Reply By: Rotty - Friday, Oct 21, 2005 at 10:11
We also run a 2002 Courier TD and find that max speed 100k/h otherwise chews up the diesel. Depending on your height may find lack of length if sleeping in the slide on. Not everyone needs to drive a Tojo or Nissan.
We have clocked up 160,000 k recently and have had the radiator checked (was about 80% blocked according to Ford) and also recently changed the original shockers. If your vehicles is regularly serviced then should not be a huge problem unless the right boot is heavy and pushy for speed. Taking it slower as we should to enjoy the drive should have little problem. Enjoy retirement when it comes.
I have another 5 years to go but am already planning for the around Oz trip on retirement.
135542
Reply By: OLDMAGPIE - Friday, Oct 21, 2005 at 17:40
my parents had an old 1tonner with a slide on did the trip 'round oz had a great time & the slide on was great did another trip & another, usual maintenance etc . they then bought a wind up van {light} & towed it for another 1/2 dozen trips this was in the 70's & they told me although the slide on was ok , towing the van' more room,setting up, maintenance, etc was a lot better. just my two bobs worth. also one of your replies mentions about the courier radiator from what ive read on this
forum & others their radiators seem to get blocked with casting sand {white} from manufacture i think. im interested 'cause i have this model also. seems to be ok for the moment but worth remembering. cheers
135624
Reply By: DEANO WA - Friday, Oct 21, 2005 at 18:39
you will almost definately have to look into suspen upgade on the back, my patrol had to, and my only prob was the amount of windage which sucked heaps of fuel and agrivated engine temp etc. we have changed to a GU dual cab with a tray top camper????????
good luck
135634
