larger offset rims
Submitted: Friday, Oct 21, 2005 at 12:43
ThreadID: 27437 Views:2948 Replies:3 FollowUps:0
I am looking for some 16x8 rims with a wider offset for my gu. I understand a landcruiser offset (say a trak2 from roh or 80 series rims) is an easy option off the shelf. Does anyone know the difference in backspacing between the standard gu and the landcruiser offset or if there are any other options? I expect many others have been down this path before?
Regards, Damon.
Reply By: toyota - Friday, Oct 21, 2005 at 13:28
if you are in vic i have a set of 16x8 silver roh sunraysias if your interested call me
on 0407358783 or 85442222
AnswerID: 135576
Reply By: haryey18 - Friday, Oct 21, 2005 at 13:35
yes 15mm difference. A landcruiser prior to 2002model was +10 and nissan was +25. after 2002 inderpendant suspension become a issue and has changed. now a landcruiser wheel shoud fit to a nissan but beware as your wheels may stick outside the guards and a nissan wheel will not fit on a landcruiser thats prior to 2002. on later models the landcruisers center hole is smaller than the nissan. hope it helps
AnswerID: 135579
Reply By: rod2101 - Saturday, Oct 22, 2005 at 23:12
landcruiser's have 5 stud wheels (5x150) after 98.
AnswerID: 135779
