Legalities of suspension bump stops...?
Submitted: Friday, Oct 21, 2005 at 15:03
ThreadID: 27442 Views:3469 Replies:2 FollowUps:3
Afternoon all.
Well, the Rangie has finally been given the boot, and a 1 year old Patrol has taken it's place (yes, shock horror, I've taken the risk on a 3.0 TD auto). First thing I noticed offroad? Clearance - or lack thereof. Approach and departure angles are fine, but ramp-over with such a long wheelbase is less than ideal (side steps have already taken a hammering). So, it's straight on the blower to Vicroads with regards to the legalities of suspension & tyres (bigger in both obviously), and the following information was forthcoming :
1. Tyre width does not go more than 25mm wider (e.g. going from 265/70 to 285/75 is ok because you have only gone 20mm wider, but 315/75 is a no-no).
2. The bump stops are not altered by more than 1/3 of their specification.
3. The rolling diameter of the tyre does not gain more than 15mm. For example, going from a 265/70x16 (overall diameter 777.4mm) to a 265/75 (overall diameter 803.9mm) is illegal, because diameter has increased 26.5mm.
Points 1 & 3 I understand, but point 2? Does it mean that at full compression, the change in axle angle isn't sufficient for you to miss more than 2/3 of the original bump stops? Assuming this, I can get a 3 inch suspension lift and bigger tyres if :
1. The bump stops are still aligned when on full compression.
2. The larger tyres clear the body at full extension and compression.
3. I get a speedo recalibration kit fitted.
4. I get all of the above verified by an engineer's certificate.
Some help on the bumpstop issue would be greatly appreciated. Also, if anyone has gone through this process, any tips & experiences would be great too. I've considered the option of just ignoring the legality (like I did with the Rangie - it had a 2 inch lift & 2 inch larger diameter tyres), but part of the finance deal is that the Patrol must be insured (and therefore legal)...
T-Bone.
Reply By: Member - Paul J (ACT) - Friday, Oct 21, 2005 at 15:09
Gday Rhyss, how ya been?
AnswerID: 135598
Follow Up By: Member - T-Bone (ACT) - Monday, Oct 24, 2005 at 17:45
Good Paul, yourself? Been doing lots of little trips back down south, but no bigger ones yet. Might be time before Christmas for a Bendethera weekend. Whaddaya reckon?
FollowupID: 389870
Reply By: Member - Paul P (Bris) - Friday, Oct 21, 2005 at 15:19
G'day
Ask VIC roads about permitted height increase ( suspension lift ). The answer should be no more than 50mm without engineering certificate.
Have a look on their web site (VIC ROADS). Qld Transport has a downloadable PDF file on vehicle mods. ALL states are supposed to have agreed to this approach (national) to modified vehicles.
Paul
AnswerID: 135600
Follow Up By: Member - Paul P (Bris) - Friday, Oct 21, 2005 at 15:49
BUMP STOPS
Cannot be decreased or increased, height/length/width/diameter, by more than 1/3 of their original specs. This one IMO is really to deal with those that lower their vehicles rather than 4wd owners.
Paul
FollowupID: 389513
Follow Up By: Wayne (NSW) - Monday, Oct 24, 2005 at 18:42
Paul,
That would be my understanding on the bump stops and lowering the vehicle.
Wayne
FollowupID: 389889
