FJ 60 - battery power drain
Submitted: Saturday, Oct 22, 2005 at 17:07
Graeme
Hi all, the battery in my FJ60 lately seems not to be holding a full charge after sitting for a few days. Before I rush out and purchase a new battery I was wondering is there a way to see if there is still power being used after the engine/lights etc are turned off. I have disconnected the clock but am not sure if power is being consumed elsewhere.
Any advice on how to check would be greatly appreciated.
Graeme
Narangba, Qld
Reply By: drivesafe - Saturday, Oct 22, 2005 at 17:51
Hi Graeme, the way to find out how good or bad your battery is, is to go to an auto electrician and get a load test done on the battery. This should be done for free, if they want to charge you, go somewhere else.
You can also get an idea if it is the battery or a drain from the vehicle by disconnecting the negative lead off the battery after you next use the vehicle. For safety reasons, do not disconnect the positive.
If the battery still goes flat then it’s a safe bet that the battery is cactus, but still get it load tested.
If the battery retains it’s charge then you will need to go looking for the reason for the drain.
Cheers and hope this is of some help.
135749
Follow Up By: porlsprado - Saturday, Oct 22, 2005 at 18:36
just curious as to why disconnect the negative only rather than both. And curious as to why you would leave the positive on ? Am thinking you'd disconnect both. Remember some time ago someone saying that,
well that doesn't matter really so just interested in your response. I mean, do you mean that something in the vehicle could hold a charge and you touching it means you take the current to the earth terminal at the battery ?
389644
Follow Up By: drivesafe - Saturday, Oct 22, 2005 at 21:19
Hi porslprado, there are a number of reasons for doing it this way but it’s especially handy when working with 4x4’s as you don’t always know if there is a second battery somewhere else in the vehicle, so by leaving the positive on the main battery, you don’t risk grounding the second battery’s positive. Even when you know your own vehicle has only one battery, it’s still a good habit to get into.
389661
Follow Up By: techie - Sunday, Oct 23, 2005 at 01:24
I was told to disconnect the negative first and connect last.
If the spanner should short between the terminal and the chassis no harm done.
If the positive terminal, one gets a hot spanner and damage to the battery.
once the negative is disconnected the battery is isolated so cannot short between the positive and negative.
Techie
389674
Follow Up By: drivesafe - Sunday, Oct 23, 2005 at 05:03
Hi techie, that’s exactly the way any decent auto electrician works and as I posted, it’s a good safety routine to get into especially when working on a 4x4. There is not only the potential of having a second battery in the 4x4 but if there is a camper trailer or caravan hooked up to the 4x4, you have an even greater chance of another battery being connected to the vehicles electric's.
Most dual battery set ups have some type of electronic isolator and should have some form of protection such as a fuse or circuit breaker in the system but there are still a lot of set ups that simply use a battery switch and this leaves the set up very vulnerable to shorting out the second battery.
It’s a simple safety routine that can save you a lot of money as
well as averting a potential danger.
Cheers.
389677
Reply By: michael42 - Saturday, Oct 22, 2005 at 20:59
Had a 60 series with a flat battery issue. The local auto sparky crawled over it, found nothing wrong, charged up the battery. Three days later I rang him from home saying the battery was flat again. He came around (he is a good guy), got it started again and took it away. Found it was the idetic (sp?) motor that wasn't cutting out properly. That was enough to drain it. If its a diesel its worth a look.
Cheers,'
Michael
135763
