Fitting PL259 connections for antenna
Submitted: Sunday, Oct 23, 2005 at 01:43
ThreadID: 27476 Views:8871 Replies:4 FollowUps:1
Anyone got any tips on fitting the PL259 connectors supplied with GME antenna to the cable? Haven't done that particular connector before.
Reply By: Bonz (Vic) - Sunday, Oct 23, 2005 at 07:32
Keep the earthed outer well clear of the inner copper wire and solder the earthed outer at the plug
AnswerID: 135789
Follow Up By: Bonz (Vic) - Sunday, Oct 23, 2005 at 07:34
Also when you wind the outer earthed sheath wires together do it in an anticlockwise direction as thats trhe direction they are helically wound hence it will reduce cable losses if wound in this manner.
Another tip: Be good to your mother.
FollowupID: 389680
Reply By: Michael Carey - Sunday, Oct 23, 2005 at 09:34
If it is the twist on type of plug......
strip about 4cm of outer black insulation off the cable, be careful not to nick the braid. Then slide the braid back along the inner conductor and using some side cutters cut the braid short until you have a rough length of 5 to 8mm of braid. Fold this braid back over the outer sleeve of the cable. This will form a thread inside the plug a little later, it doesn't need to be too long. The longer it is the harder it is to screw it into the plug!!
Strip the inner conductor leaving about 10mm of insulation, be careful as pulling the insulation off can also make the inner conductor pull out from the cable. I usually tin the inner conductor with a soldering iron and solder, just to make sure there are no 'whiskers' of wire that can short out inside the plug.
Unscrew the locking ring off the plug and slide it onto the cable FIRST, making sure you get it the right way around...
Then, carefully insert the cable into the plug and screw it into place. The thread inside the plug forms a thread on the braid, this makes a solid contact between the plug and braid. Don't screw the cable all the way in as then you will short out the braid against the centre pin of the plug!!!
Trim the centre conductor flush with the end of the centre pin and solder. You don't need much solder, and don't apply too much heat... some plugs have a plastic insulator that can melt with excess heat!
After is has been left to cool a little, slide the locking ring to the plug and screw it back into place. If you have a multimeter, make sure you don't have a short circuit, taking into account that some antennas normally measure a short circuit!!
I have been meaning to take some photos of plug assembly and post them in my webspace, I hope the above gives you some idea of what to do....
AnswerID: 135805
Reply By: res.q.guy - Sunday, Oct 23, 2005 at 11:52
Hi...
If you or a friend has a current copy of the 2005/2006 Dick Smith Catalogue, there is a step by step description including diagrams on page 351.
It shows how to wire the popular RF plugs inc PL259.
Or it's on their web site :
www.dse.com.au/cgi-bin/dse.filereader?435aec5b065e7878273fc0a87f9c06ea+EN/catalogs/SUP0001869
Regads
Neil
AnswerID: 135819
Reply By: joc45 - Sunday, Oct 23, 2005 at 15:03
I have discovered a shocker of a PL259 connector, which a friend fitted to his rig. The cable is just snipped off square, the centre pin of the connector has a spike which shoves back under the dielectric and makes contact with the inner conductor. A grub screw in the side of the connector screws in to make contact with the braid (a small nick is made in the insulation so the grub screw can connect.
This sort of connector should be thrown out, and a proper one as described above used. Apart from the chance of the braid touching the inner (which this one did), the performance at UHF would be abysmal. And there is no strain relief.
Having said all that, if you have an ohm meter, check that the inner hasn't shorted thru to the outer once you put it all together.
Gerry
AnswerID: 135830
