HZ75 aircon leak.......
Submitted: Sunday, Oct 23, 2005 at 20:51
ThreadID: 27492 Views:2189 Replies:3 FollowUps:2
My Trayback leaked cold water inside the cabin today coming from the Aircon. I'm sure that has happen to others before. As nice as it is right now here in Brisbane to get cold water on your feet while driving I think I should fix it soon. Any ideas?
Reiner
Reply By: Member - jucky - Sunday, Oct 23, 2005 at 21:05
my aircon did the same thing once and after a quick inspection i found the drip tube that passes through the firewall on the passenger side had lifted and was sitting on the inside of the cab ( maybe worth a look ???)
AnswerID: 135892
Follow Up By: Member - Reiner G (QLD) - Monday, Oct 24, 2005 at 15:27
Yes, the hose was off the drain pipe....... ( thanks mate) must be the womans fault pulling it down with her feet. 2 weeks no TV sounds fair? :-)
Reiner
FollowupID: 389844
Reply By: vitara - Monday, Oct 24, 2005 at 12:54
Hi there rhino, you might also need to take the hose off the bottom of the evaportor (under dash), and just poke a cable tie or something of the sort to make sure the hole isn't blocked, dont use coat hanger wire incase you stab the evaporator and put a hole in it then your in the sh@t. Also blow the the drain tube to make sure it is clear. Thats why I always run my air on recirculate insteasd of fresh when on a dusty road so (1) you dont get the dirt in the cabin and (2) so that it doesn't suck the dirt into the evaporator mixes with the condensated water which then turns into mud blocking the drain tube, also I try to avoid parking under trees that drop those pain in the ars@ little leaves that go down through the vents near your wipers get sucked into the condensor box and wella another blockage. Just some helping tips. Have A great day Vitara
AnswerID: 135999
Follow Up By: Member - Reiner G (QLD) - Monday, Oct 24, 2005 at 15:29
Thanks Vitara, good thinking..... never did much thinking about the airconditioner as long as it blows cold air :-)
We need it right now here in Brisbane.....but we are getting rain tonight.
Hope we do.
Reiner
FollowupID: 389845
Reply By: Member - Davoe (Widgiemooltha) - Monday, Oct 24, 2005 at 15:37
Get your flexibility working and shove tour head with a torch up under their. last time it happened in a work vehickle it was just a matter of plugging 2 joins back together
AnswerID: 136025
