Vibrating BullBar
Submitted: Monday, Oct 24, 2005 at 12:38
ThreadID: 27505 Views:2563 Replies:5 FollowUps:2
We have a ARB steel bar (with Warn M8000) on a Rodeo. On 'dirt' roads eg Central Road/ Oodnadatta track etc- the bar vibrates quite noticably. So much so we have sheared 3 UHF antenna s so far- both spring mounted and not spring mounted.
All the mounting bolts are tight- there are no elongated holes, and all mounts onto chassis appear strong. It just disconcerting with the vibes.
Any clues anyone?????
Reply By: Leroy - Monday, Oct 24, 2005 at 12:56
I had the exact same setup on my Rodeo and didn't have a prob with a polar spring mounted antenna. What I did notice though was that the body moved around alot with respect to the bullbar.
Leroy
AnswerID: 136001
Follow Up By: signman - Monday, Oct 24, 2005 at 13:14
Thanks Leroy. The snapping antennas is only a sideline to the problem. I have relocated the uhf (on side of roofrack)- but I am concerned with the vibrations of the bar.
Is it the body moving?? but the oscillations are thru the bar!!
FollowupID: 389826
Follow Up By: Leroy - Monday, Oct 24, 2005 at 13:32
my body moved to such an extent that the 'wings' on the side of the bull bar touched the guards on not only mine but a friends also.
Leroy
FollowupID: 389827
Reply By: Wayne (NSW) - Monday, Oct 24, 2005 at 13:31
Signman,
It is a common problem with the Jackaroo as well as the Rodeo. you will find a big gap, or there should be one between the wing of the bull bar and the guard. This allows the body to flex.
From what I have noticed is the body moves a lot on the chassis, and for the body to flex the chassis must also be moving. In a way this is good. It means that on uneven tracks or rock hopping the body will flex a little and not crack. On the road this is not so good as it means that the bull bar is now vibrating along with every thing that is attached.
Spring mounted aerials are the way to go the shorter the better, but this is not always possible. I have had a good run with the broom stick type aerial on a large spring. It stills moves about but it has not broken. I have had it on the Troopie for over 12 months and 65000km on some very rough roads and it is still going strong.
I don't think it would matter what suspension you have will solve the problem as I have seen the vibration with stock vehicles as well as tricked up ones. All vehicles vibrate and flex, some more than others.
Wayne
AnswerID: 136009
Reply By: MATT.D(WA) - Monday, Oct 24, 2005 at 16:22
Signman,
My old Jackaroo used to have the same problem so I tried all sorts to fix it. Thought it was the brackets down to the chassis causing the problem so I joined them together to reinforce them against vibration. Tried drilling an extra bolt hole but this did not work. Came to the conclusion in the end that it was something I had to live with.
Matt
AnswerID: 136037
Reply By: Dion - Monday, Oct 24, 2005 at 22:55
I use GME 4705 antenna's, 120k's on 2.8TDi Rodeo, 60k's on 3.0TDi Jack and 50k's on 3.0TDi Rodeo and all holding up well with no apparent signs of fatigue
Dion
AnswerID: 136147
Reply By: Big Woody - Tuesday, Oct 25, 2005 at 04:28
Hi Signman,
It seems to me that your chassis is virating uncontrollably on these corrugations and as your bullbar is mounted directly to it you can actually see what the chasis is doing. Sooner or later this will take it's toll on your body mounts and rubbers too.
I would upgrade the shock absorbers on the vehicle to some very heavy duty big bore oil shockies (like Koni's) as this is the part of your suspension system that is designed to try and control this issue. Remember some shockies seem to work fine when they are cold or working normally on the bitumen but hours of corrugations can make some of the best shockies (especially gas shocks) almost totally lose their ability to absorb corrugations.
Just my 2 cents and good luck in solving this issue.
Brett
AnswerID: 136164
