12v Extension?
Submitted: Tuesday, Oct 25, 2005 at 13:36
ThreadID: 27546 Views:5198 Replies:6 FollowUps:1
Has anyone seen or made or heard of a 12v extension cord for a WAECO ( 80lt). I would like to run it 2mtrs from my C/T for short periods ( 24-36hrs). According to the instructions this is not advisable but I thought you inventive types may have a solution…
Brad..
Reply By: Wizard1 - Tuesday, Oct 25, 2005 at 13:50
Get some 2 core cable (Repco, etc). Cut the Waeco cable and solder/connect the new section on.
I have two 12 volt cables for my Waeco. One has the standard Waeco 12 volt fitting, the other a Narva type (much better when in the vehicle as it doesn't drop out).
Can't see why it is a problem as long as your connections, etc do not cause voltage drop. The 2 core is usually of an acceptable size not to cause this. The current cable is a metre or so long already!
Wizard
Gold Coast
AnswerID: 136227
Can't see why it is a problem as long as your connections, etc do not cause voltage drop. The 2 core is usually of an acceptable size not to cause this. The current cable is a metre or so long already! You would get more voltage drop through the poor Waeco connection as you would through extra cable.
Wizard
Gold Coast
AnswerID: 136228
Reply By: flappa - Tuesday, Oct 25, 2005 at 14:04
Yeah , what Wizard has said . . . said.
Make up your own. If its of sufficent thickness , you are unlikely to have a problem.
AnswerID: 136230
Reply By: Patrol22 (Queanbeyan - Tuesday, Oct 25, 2005 at 14:26
Hey Chief - this might mean taking it down to the FIMA guys in your case? But seriously an alternative approach is to do what I have done (and it works well) - make up a 2 metre extension cable with the right male/female plugs. It will also come in handy for other things as well - eg the 12V shower etc.
Pete
AnswerID: 136239
Follow Up By: CPOCK - Tuesday, Oct 25, 2005 at 14:40
A pack of tim tams should cover it ??
FollowupID: 390075
Reply By: kev.h - Tuesday, Oct 25, 2005 at 18:31
go to your local auto electrician and buy 6mm2 twin core cable this is good 3-4m @3.5 AMPS 12V with buggerall voltage drop
if you can source the plug for the fridge if not just a good quality socket and plug your cord in
seeing your fridge has low voltage cut out it may cut out a little earlier than normal
due to voltage drop at startup
if you have a cord made that comes direct from the battery to the fridge lead it is no different to plugging into a socket in the rear of the 4wd it would be about the same distance
regards Kev
AnswerID: 136284
Reply By: Alloy c/t - Wednesday, Oct 26, 2005 at 14:22
Cpock , have a look at the instructions that came with fridge and the 240v convertor[mobitronics] ,has provision to wire staight to battery , all u need is some heavy enough gauge wire ,, according to the waeco chart that came with your mobitronics.
AnswerID: 136469
