Inverters
Submitted: Wednesday, Oct 26, 2005 at 19:16
scottywiper
If I want an inverter to run a laptop off and charge cameras, video cameras, etc, has anyone got any recommendations?
Scotty
Reply By: Willem - Wednesday, Oct 26, 2005 at 19:34
Scotty
I run a Pure Sinewave 150 watt inverter to charge batteries and run my night light.
I run my laptop off a Kerio DC charger through the cig lighter socket.
136508
Follow Up By: Truckster (Vic) - Thursday, Oct 27, 2005 at 00:21
Where did you mount your inverter..?? Was talkin to Adam about these tonight
390310
Follow Up By: Willem - Thursday, Oct 27, 2005 at 06:58
The inverter started off in the glovebox but I have now shifted it to the dashboard, in front of the sissy bar. It is velcroed to the dashmat and powerchords have been wedged in between doorlining and dash and through grommet in firewall. I have a colour matched towel that covers it and protects it from the sun.
I used to run the laptop from the inverter and that is why I bought a Pure Sinewave but I found that the Kerio works much better for running the lappy. Now I only charge camera batteries from the inverter and run my 240volt fluoro at night.
Did you get my emails re parts etc?
390316
Reply By: atoyot - Wednesday, Oct 26, 2005 at 21:15
A pure sinewave inverter is worth getting if you're not going to get a Kerio as Willem has. Modified sine wave
inverters tend to stuff batteries after a while, and laptop batteries aren't real cheap. I'm sure that someone has a technical explanation as to why the pure sinewave
inverters are best.
136526
Follow Up By: V8troopie - Thursday, Oct 27, 2005 at 00:07
I doubt that "stuff batteries after a while" statement. The inverter does not power the battery directly, but the battery charger. Since this is a switch mode device, IT might get stuffed - aka run a bit hot if left on for long (
mine didn't, but I only used it for a short time, less than 1/2 hour at a session).
The DC output the computer battery gets from the charger is the same.
For only running a laptop the Kerio is the better option as it converts DC directly to the higher voltage required, one less gizmo to pack, it is considerably smaller than an inverter and only slightly more expensive than a modified sine wave inverter.
Klaus
390309
Reply By: Matt (W.A.) - Wednesday, Oct 26, 2005 at 21:29
Scotty,
I was told that the Pure Sine
Inverters have a Cleaner Current as apposed to Modified Sine that’s why I picked up a 600W Pure Sine Inverter from DSE from Memory for $189.00! I think? I run the Xbox and a 15' LCD Screen of it no worries plus it charges the Lappy, iPod and Camera Batteries….ect
Matt
136529
Follow Up By: Volante - Thursday, Oct 27, 2005 at 08:05
DSE has only sold a 300w sine wave inverter for $294
no other sizes in sine wave from DSE
390327
Follow Up By: Matt (W.A.) - Thursday, Oct 27, 2005 at 20:43
OOps.....
Sorry Volante Your dead right I had a 150W Modified Sine and Now I have a 300 Pure Sine it runs everything i mentioned above no problems (Not all at the same time though!)
Matt ;-)
390459
Reply By: Volante - Wednesday, Oct 26, 2005 at 21:29
we use 150w sine wave
inverters in our reps cars to charge the laptops for $200
have one in the caravan to charge the laptop and other batteries. In summer we use a 240v fan as no noise more air and less power cheaper than 12v fan
http://members.dodo.net.au/~landline/
inverters.htm
136530
Reply By: Member- Rox (WA) - Thursday, Oct 27, 2005 at 00:59
I've had 2 digitor 300w burn out in last 12 months so changed brands.
Mine is mounted to the cargo barrier by flat OKI straps.
136555
Reply By: techie - Thursday, Oct 27, 2005 at 01:30
Ah,
Inverters.
Modified sine wave == square wave with the sharp corners removed.
Good for equipment that have switch mode power supplies in them.
ie TV, videos, some laptop power supplies.
Pure sine wave == 240V AC supply.
good for any equipment.
esp fridges, and other equipment that need a real power supply. ie not switch mode.
simple explanation:
power dissipated = voltage X current.
for "modified" the switching transistors are either fully on or off.
ie
On 0V * 10A = 0 watts
Off 240V * 0A = 0 watts
minimal power dissipation in transistors. rating is in transformer
Modified is more efficient but has limited uses depending on equipment.
for pure sine wave the transistors are transient
ie in middle of cycle 120v * 10A = 1200 Watts
so power during one cycle of 240v changes from 0 watts to 1200 watts and back to 0 watts.
Therefore pure produces less output for size and has less efficiency (some power is dissipated in the switching transistors) but will power any 240V ac device.
ps. is there some way one can upload graphic details for things like this for all to view? A section of the site for people to find answers instead of asking the same questions over and over again? A way of helping people to understand what is actually happening and helping members for future problems?
Techie
136557
Follow Up By: Volante - Thursday, Oct 27, 2005 at 08:00
there is no such thing as 'modified sine' wave.
'Therefore pure produces less output for size and has less efficiency' tis not true as you can purchase sine wave
inverters that are 96% efficient
my brother sitting here next to me telling me what to type says "
sign up for a technical course on electrical engineering"
my brother says there are many more inaccuracies in your message than things that are right
390325
Reply By: atoyot - Thursday, Oct 27, 2005 at 10:32
Sorry, I should qualify my "stuff batteries" statement. Running a laptop from a "non pure sinewave" inverter using the normal 240v adapter seems to stuff batteries, in my limited experience. I don't know if this is any different to using a battery charger for, say, video camera batteries the same way. I've used
mine for video and digital camera batteries with no trouble, but I suppose it's a bit different to using a laptop from in inverter. Ultimately, if you use a laptop from AC power all the time, after a while the battery will cease to work. I suppose that's why laptop manuals usually recommend cycling the battery by using it on battery from time to time. I'm still not sure about the difference between pure sinewave
inverters and laptop batteries,
136589
Reply By: Coyote - Thursday, Oct 27, 2005 at 10:36
I certianly don't have the technical guru advice mentioned above, but I have very dsimple 80W Inverter I purchased from Dick Smith for about $80. I have it mounted under the passengers
seat and I modified it so rather than havng to plug into it under there.. there is a switch on the center console and a power point next to the gear stick. I runa ;laptp off it just fine (when running off 240V Laptops should always have the batteries removed otherwise you are overhcarging them) (oncve they are fully charged of course) I also charge mobiule phoe and run battery charger for the torch AA and D cells..
All I can say is it all works beautifully for 12 months now. Have just moved to new Nissan and wil lbe reinstalling the same set up...
136591
Reply By: atoyot - Thursday, Oct 27, 2005 at 11:01
I knew I saw it somewhere. Try this: (hope it works)
link text
136598
Reply By: cuffs - Thursday, Oct 27, 2005 at 14:05
Any one run an Engles fridge off the inverter and for how long?
136638
Follow Up By: MartyB - Thursday, Oct 27, 2005 at 21:01
There would be no point in running an Engle off an inverter. More efficient would be to run the Engel off the DC.
390461
Reply By: scottywiper - Thursday, Oct 27, 2005 at 20:06
Thanks for all the advice guys.
I ended up going with a 300W (1000W surge) mod sine wave inverter from Jaycar for $99.
I consulted with my father, who is a former electrician and a whiz on all things electrical.
Hope this also helps others!
Scotty
136682
Reply By: atoyot - Thursday, Oct 27, 2005 at 21:25
Page 233 of the DSE 04/05 catalog has a bit of a blurb on
inverters, efficiency and power usage etc. THey also mention about the potential for "actually destroy the laptop battery packs". So it seems that intermittent usage on a normal inverter won't hurt the laptop battery, but they are not real clear about how long they can be used without damage. I've seen one stuffed, so with batteries being between $100 and $300, it's sort of line ball between a normal inverter and a sine wave inverter.
Whats the saying, "Caveat Emptor"
136691
Reply By: techie - Thursday, Oct 27, 2005 at 21:52
Volante -
sign up for electrical engineering - I am one.
Have been doing this since mid 70's.
I only give the knowlege I have - Not tear down someone elses.
Techie.
136696
