waeco error light
Submitted: Friday, Oct 28, 2005 at 20:52
ThreadID: 27643 Views:14301 Replies:8 FollowUps:2
I have a new Waeco cf50 It cools perfectly but the error light flashes all the time. It has only been run on 12 volts so far. Anyone had this problem?
Reply By: Brew69(SA) - Friday, Oct 28, 2005 at 20:59
Try it on 240. If it doesn't do it then maybe you are not supplying enough juice on 12v.( not heavy enough wire to plug)
AnswerID: 136845
Reply By: dazza0503 - Friday, Oct 28, 2005 at 21:11
Just using cord and plug supplied, plugged into a bushranger 2600 powertank on constant 240volt charge It also powers on( as in compresor ) for 30 seconds then of then back on one minute later. Seems strange.Is this normal?
Thanks for any help
Dazza
AnswerID: 136848
Reply By: Member - Banjo The First (SA) - Friday, Oct 28, 2005 at 21:36
i just bought a new CF60 and am rapidly learning about power supply for fridges. Slow flashing of the red light says your voltage is too low fas as I recall from the destructions. Regardless of your power arrangements, the voltage at the fridge's inlet plug, when running, is what matters. 1. Check that you have the low voltage cutout all the way to the left (10.5V). 2. You may need larger capacity wiring from the battery to your fridge - voltage drop was my problem and I'm working through that issue now. From my reckoning, the bloody Waeco power cable loses near on half a volt in itself - not good.
AnswerID: 136852
Reply By: dazza0503 - Friday, Oct 28, 2005 at 21:49
Thanks Banjo
My instructions say. Error LED flashes red in case system is not ready to operate.I'm waiting for it to be ready? Two weeks should be enough
AnswerID: 136853
Follow Up By: Mainey (WA) - Friday, Oct 28, 2005 at 22:21
.......Does it work correctly on 240v ???
FollowupID: 390617
Reply By: The Rambler( W.A.) - Friday, Oct 28, 2005 at 22:38
Buy an ENGEL
AnswerID: 136858
Reply By: Dave ....Adelaide - Saturday, Oct 29, 2005 at 00:07
I also have a cf50 , whilst we were away earlier this year my error lite was flashing all the time also , after much stuffin around changing battery and whatnot i discovered it was actually the 12 volt cord where it connects onto the fridge wasnt making proper contact, the fittings inside the plug on the cord must have worn or something , i stuck some alfoil inside the conections to get us through until we could get a new cord ......problem solvered ........Cheers
AnswerID: 136869
Follow Up By: Member - Banjo The First (SA) - Saturday, Oct 29, 2005 at 14:20
Bl***dy choice ! - If I could find the same inlet plug as a spare' I'd make up a whole new cable of my own with heavier cable - better than the one supplied I'd say - less (maybe zero) voltage drop and more robust overall I'd guess.
FollowupID: 390649
Reply By: res.q.guy - Sunday, Oct 30, 2005 at 08:04
There is an "error type" dependind on the number of times the error light flashes.
ie a no. of flashes then a delay then a no. of flashes again.
5 flashes - Thermal Cut-Out. The refrigeration system is too heavily loaded or the ambient temp is too high.
4 flashes - Minimum Motor Speed. The refrigeration system is too heavily loaded, the motor speed cannot maintain minimum speed - approx 1800rpm.
3 Flashes - Motor Start Error. The rotor is locked or the differential pressure in the refrigeration system is too high(>5 bar).
2 Flashes - Fan Over Current Cut Out. The fan is loads the electronic unit with more than 1A.
1 Flash - Battery Protection Cut Out. The voltage is outside the cut out setting.
This should help you into which area to look at.
It is most likely voltage drop that others have covered.
Neil
AnswerID: 136974
Reply By: arofs1 - Sunday, Oct 30, 2005 at 20:48
Dazza, I have a Waeco, as does my brother in law. I am sure you will find that there is an earthing problem. If you read the instruction Waeco manual closely it says to earth the fridge directly back to the negative pole of the battery. Many people earth the negative power lead to the chassis or frame of the vehicle. This can work in some cased if the contacts between all parts of the vehicle are very good, but it depends how efficient the the connection is between the earth wire of the fridge back to the actual battery negative post.
I have two recent esamples:
(1) I had a fridge in the rear of my hilux which had an aluminium tray. I brought the positive from the battery to the fridge plug and connected the negative direct to the frame of the tray instead of wasting extra wire right back to the battery. It worked initially, but the voltage dropped from about 12.7 to 11 volts under load. This is because aluminium is not a very good conducter, particularly where it joins the steel chassis. After returning the negative lead direct to the battery as per the manual, it worked perfectly.
(2) I recently went to the Birdsville races with my brother in law and his fridge red light kept flashing like yours when on 12 volt battery power. His system was installed by a professional!!! I discovered an identical problem to my own previous experience, in that his earth was connected to his tray which obviously did not earth properly back to the battery negative post. To test my theory I just connected a battery jumper lead from where the earth lead met the tray direct to the battery negative post, which was fairly close and it then worked perfectly with no flashing lights.
If I were a betting man I would ...............
AnswerID: 137073
