Sand spear
Submitted: Saturday, Oct 29, 2005 at 05:57
ThreadID: 27649 Views:13987 Replies:4 FollowUps:4
Does anybody have a design for a home made sand spear. Hear they are not that hard to make from plastic conduit .
I and am not prepared to spend $700 for a stainless steal one.
Redeye
Reply By: Big Woody - Saturday, Oct 29, 2005 at 06:13
Hi Redeye,
I purchased my 4ft stainless sand spear at the local agricultural plumbing supplies for $150.00 brand new.
It may pay to check some other suppliers.
Brett
AnswerID: 136877
Reply By: Willem - Saturday, Oct 29, 2005 at 07:44
Three star pickets tied together in line will do the same job. Cost about $15
Alternatively bury the spare wheel. It works, believe me.
AnswerID: 136882
Follow Up By: Redeye - Saturday, Oct 29, 2005 at 07:46
Thanks Willem,
But I was thinking of the one you use on the beach to get bathing water.
Redeye
FollowupID: 390629
Follow Up By: Willem - Saturday, Oct 29, 2005 at 08:01
Hahahahahaha......You got me there.
Methinks I was thinking of sand anchor lol
I would say that the same principle would apply. If you used polypipe and strenthened it with a steel rod it should work. Not sure if the spear has a mechanical suction pump? One must always think outside the square and try to make these things yourself as sometimes the market price is ridiculous
FollowupID: 390632
Follow Up By: V8troopie - Sunday, Oct 30, 2005 at 01:13
Redeye, you got me curious now. 'Bathing water' at the beach? am I right in assuming it is still salty? What quantity can you expect from the spear before it gets all pumped dry?
Klaus
FollowupID: 390706
Follow Up By: Big Woody - Sunday, Oct 30, 2005 at 06:41
Hi Klaus,
Sand spears are very common on coastal areas of Queensland for pulling underground fresh water out of the sand.
I grew up on the Gold Coast and nearly every second or third house had a spear pump. The water table at Miami in the middle of the Gold Coast was 12ft below ground level so our sand spear was put down at about 20 ft. Once the spear is in the ground at these depths you can never retrieve it as it is not like a bore with a casing around it. Some people try it with a casing and have problems with it sucking air from the surface instead of drawing the water from the ground around the spear.
Now I live in Burnett Heads near Bundaberg and the water table at my house is only about 8 ft below ground level. When I was first putting down the spear I had bored the hole for the spear and you could see the water table rise and fall with the tide.
I have a grundfos pump with no pressure switch and this will run 3 sprinklers flat out. Endless water for free is great when everybody else is under water restricitions. The spear pump was used at our Gold Coast house for about 4 hours each day for 15 years and never ran dry.
I have no problems with sulphur smell in the water or staining but I remember on the Gold Coast even though the water was very pure, some times the spear water would smell. We took samples and had the water tested by the council and it was better quality than the town water they said.
You guys have me thinking now as I have never thought of using this concept but on a smaller scale for camping at Fraser Island etc.
Brett
FollowupID: 390710
Reply By: Redeye - Sunday, Oct 30, 2005 at 07:04
Hi Klaus
Try these two sites they cover the sand spear.
http://motorcare.com.au/sspear.htm
http://www.glind.com.au/htm/product.asp
Redeye
AnswerID: 136971
Reply By: Brian B (QLD) - Sunday, Oct 30, 2005 at 12:27
As stated earlier have a look at the Glind website. They have the stainless steel authentic sand spear for $385.00.
AnswerID: 136998
