mounting fire ext. in cab chas
Submitted: Sunday, Oct 30, 2005 at 14:26
simple
has anybody mounted a fire extinguisher in a ute, where? just bought a 1kg ext. but now i can't work out where to put it. thought about behind the seats but i don't really want to put holes through the panel thats only 1 layer and its a bit hard to get too.
how about on the roof above the passengers
seat on the bit of metal the light is on.?
p.s. its a patrol c/c
Reply By: rickwagupatrol - Sunday, Oct 30, 2005 at 14:31
hiya simple, just mount it in the passenger side footwell, i have
mine mounted of the side of the console.....had to drill a few holes in it, but can get those plastic pluge to fill the holes when i sell the car.
rick.
137016
Reply By: Bruce QLD - Sunday, Oct 30, 2005 at 15:03
I've got
mine mounted under the drivers
seat across the front so it basicaly sits behind your ankles type of position. dosent get int the way and is very easily acessable if ever needed.
137022
Reply By: Member - Willie , Epping .Syd. - Sunday, Oct 30, 2005 at 16:51
I have got the 1.5 kg Chubb bottle and I felt that with only one strap holding it , it might come out of the bracket in an accident . It really would go right through you if it hit you .
So off I went to Chubb to see what they could do about it . I told them it was to be mounted in my racing car and that I was very concerned about the fact that it only had the one bracket yabba yabba yabba .
They replaced my holder with a tighter one and let me keep the old one . I cut the bracket off the old one and put it onto the new one to give it great security .
I mounted
mine under the cargo platform I have added after I took both the rear seats out . ( my car is a two seater now )
When I had my track car , I mounted the bottle transversly in front of the drivers
seat . It never got in the way there . I would have done the same with this car if I had not fitted the cargo platform .
Cheers .
137032
Reply By: Casnat - Sunday, Oct 30, 2005 at 17:12
I resist drilling any new holes as much as I can. In my GU I mounted
mine horizontally across the front of the bottom of the drivers
seat using 2 existing screw holes. I removed the screws that were in there (and put them aside for when I want to return everything to normal) and with some longer screws mounted a 9cm x 30cm piece of maisonnite (spelling?) which essentially hangs down from these mounting screws on a bit of a slant backwards. I mounted the normal plastic extinguisher bracket to the maisonnite.
Have been over heaps of rough tracks and it hasn't moved. Sits out of the way behind your ankles (as someone else said). Its mounted to the
seat and moves forward / back with the
seat if you adjust the
seat.
Not sure if all Patrol seats have these screws or if my model is different.
Mine is a Ti which again may make a difference.
Trevor
137035
Reply By: ellmcg - Monday, Oct 31, 2005 at 10:20
Someone said it further up the discussion - under/just in front of the drivers
seat. It keeps the 'stuff' from sliding forward from behind the
seat too!
137126
Reply By: Member - Andy C (WA) - Monday, Oct 31, 2005 at 19:23
I had
mine fitted under/in front of the passenger front
seat. I used the existing
seat fixing bolts to bolt a piece of flat steel between those bolts and fixed the extinguisher to that.
Beautiful!
137179
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Nov 02, 2005 at 03:10
No one else has said it but i utes with extinquishers every day and there are 3 spots In the back for large ones. Behind the ankles like already described and (even better) is below the
seat at the side eg open the door and looking at the
seat there is room below the
seat between the door - out of the way of everything
137379
