uhf radio purchase
Submitted: Sunday, Oct 30, 2005 at 21:12
ThreadID: 27684 Views:3063 Replies:5 FollowUps:1
what mid priced uhf radio to purchase for out back travel
Reply By: Member - Paul P (Bris) - Sunday, Oct 30, 2005 at 21:49
G'day
Your brand choice are GME (my preferred) Icom and Uniden. The key to maximum performance is the antenna. The GME site has good info on antenna choices.
In cars should be 5 watt output. The cheaper handhelds are only for short distance comms.
GME UHF Transceivers and Antennas
I currently run a AE4703/G antenna (GME) as I have had the lighter ones fail after extensive corrugations due to excessive antenna movement.
Paul
AnswerID: 137085
Reply By: muzzgit (WA) - Monday, Oct 31, 2005 at 02:29
Ewez, that all depends on whether you can fit it into the dash, under the dash on the side of the centre console or, like me, on the back of the centre console.
A good place to start would be the Uniden UH088sx. Good size, front speaker, cellcall, and not too expensive. As for outback travel, as long as it has 5 watt power it will do the job.
AnswerID: 137111
Follow Up By: GeeVee - Monday, Oct 31, 2005 at 10:35
EWEZ,
I'm with MUZZGIT. I'm in QLD, ordered one through Prestige Communications in WA last week, fitted it on the weekend. $295 for radio, aerial and cable. Ordered 3pm Wednesday, arrived 11am Thursday. I'm impressed!!!! I know GME and ICOM are supposed to be better quality, but I have a Uniden in another vehicle and have not had any problems. I think they are good value for money.
FollowupID: 390828
Reply By: Member - Phil G (SA) - Monday, Oct 31, 2005 at 16:30
Ewez,
The "outback travel" bit has me a little puzzled.
Are you aware that UHF is limited to about 30km range, and that your only chance of extending that is through repeaters that are usually only found on fringe areas of the deserts. So as a means of emergency communication, they may not be very good.
phil
AnswerID: 137168
Reply By: madcow - Wednesday, Nov 02, 2005 at 13:49
I have a GME tx300 along with a GME mk4 extension speaker for sale if your interested. It was owned by my old man who only use it for caravanning and is in excellent nick.
$220.00 ono
dave.charlton@ap.effem.com
AnswerID: 137424
Reply By: wazzarrr - Thursday, Nov 03, 2005 at 09:05
hi ive a uniden gps 105 fantastic unit 5 watts and also a gps unit .
this allows you to set gps points so you can get back to that position.
AnswerID: 137555
