DVD capacity
Submitted: Monday, Oct 31, 2005 at 12:37
ThreadID: 27694 Views:2048 Replies:6 FollowUps:0
Here is one for the electronic wiz kids.
I have bought a new fang dangle video recorder that takes video and puts it straight onto the little 30 minute dvd's.
On my desert trip I took 6 of these which equates to 3 hours of footage.
Now for the question, How many minutes is a 4.7 gig dvd disc? I have only just learnt to make dvd's with my burner on my computer and that has taken me 12 months so I am no wiz at this.
All the disc says is 4.7 gig.
Any help would be greatly appreciated.
120scruiser
Reply By: flappa - Monday, Oct 31, 2005 at 12:41
A DVD has approx 2 hours of Vid footage.
That can be changed with various compressions etc, but, essentially, a single layer 4.7g DVD can have 2 hours of video
AnswerID: 137140
Reply By: techie - Monday, Oct 31, 2005 at 13:50
I would say that the video on the 30 minute mini disks is not in DVD format but VideoCD or SuperVCD (SVCD) format.
They are far more efficient enabling one to put an hours video on an 80 min CD.
This can be transferred to computer and cut/ joined etc etc and then burnt to a CD for use in DVD player (if it plays VCD or SVCD).
converting from vcd to DVD format is not easy and why would you want to?
try going to video help this site may help you.
might also want to try DVD hacks
Techie
AnswerID: 137146
Reply By: Member - TonyG (Qld) - Monday, Oct 31, 2005 at 15:34
Hi 120,
I will assume you have purchased a Sony brand dvd recorder which is the same as mine.
Each disc holds a total of 1.44 GIG storage capacity. If you record in mpg2 format (standard), you will get approx 30minutes of video. If you record in mpg1 format (long play), you will get 60 minutes of video.
It doesn not matter which format you record in, the small disc still holds 1.44gig of fottage.
With a standard dvd disc being 4.7gig capacity, I would only recommend using no mor than 4.4 gig, as the outer edge of some disc's are a bit dodgy.
This will mean you can get 3 small recorder disc's of footage onto a single standard 4.7gig disc.
Hope this helps.
TonyG
AnswerID: 137163
Reply By: Member - Andrew L (VIC) - Monday, Oct 31, 2005 at 17:34
Hi there,
I use dvdshrink
to compress files to fit on a disc. Well worth a try.
AnswerID: 137173
Reply By: 120scruiser - Monday, Oct 31, 2005 at 19:30
Thanks all
It looks like I have some homework to do and lots of time behind the screen.
120scruiser
AnswerID: 137181
Reply By: Member - Karl - Tuesday, Nov 01, 2005 at 09:40
I also use DVD Shrink - a great freeware program. If you are going to use it make sure that use set it to only burn to 4300MB, this will prevent you burning all the way to the end of the disk and thereby potentially loosing some of your data.
To do this - once you have downloaded the program, click on the 'Edit' button, go to 'Preferences' then select 'Custom' and set it for 4300MB.
If you want a good guide on how to use DVD Shrink go to www.afterdawn.com.
Karl
AnswerID: 137264
