UHF & 100 series
Submitted: Monday, Oct 31, 2005 at 20:15
ThreadID: 27700 Views:1965 Replies:6 FollowUps:5
Well after much thought and stripping , I had to re think were the UHF was going to go , In the end I ended up fitting it to te side of the concole , Originaly I thought it would be a pain to see , but go the angle right and its not to bad , I can see the channels atleast whislt im driving to change if i have to .
Ill try load a pic !MPG:3!
Reply By: Member - Alan H (QLD) - Monday, Oct 31, 2005 at 20:26
Looks like a neat job. Trust your left leg doesn't catch on it.
My mate with a 100 series had the same problem and eventually put his in a roof console.
Whatever works for you is what matters. Yours looks very professional and trust it suits you fine.
AnswerID: 137192
Follow Up By: Rock Crawler - Monday, Oct 31, 2005 at 20:37
the photo is deseving , the unit only sticks out 25 mm , so its only the face thats showing.
FollowupID: 390916
Follow Up By: Rock Crawler - Monday, Oct 31, 2005 at 20:40
to give a idea of how much it sticks out , I can still move the seat all the way forward and it dosnt touch the seat
FollowupID: 390918
Reply By: Willem - Monday, Oct 31, 2005 at 20:33
Hmmmmmm Might have to tie your legs together with an ocky strap lol
Does the radio fit into console space or did you have to cut through the gearbox tunnel?
AnswerID: 137194
Follow Up By: Rock Crawler - Monday, Oct 31, 2005 at 20:38
goes into the gap of the concole lol , it was the only place that didnt have a computer somwere lol
FollowupID: 390917
Reply By: Member - Alan H (QLD) - Monday, Oct 31, 2005 at 20:40
Is the radio one with a remote head and the main body of the radio is elswhere?
AnswerID: 137195
Follow Up By: Rock Crawler - Monday, Oct 31, 2005 at 20:45
all in one unit Alan , the unit is slotted into the concole , If I had a remore head unit , I would have pit the contol on the top side of the concole .
FollowupID: 390922
Reply By: Member - Alan H (QLD) - Monday, Oct 31, 2005 at 20:46
If you can move the seat with no bother you have found a great spot.
I was more concerned about the mic lead rather than the face of the radio.
That spot looks just great - out of the way - short distance to electricals etc - well done.
AnswerID: 137196
Reply By: V8Diesel - Monday, Oct 31, 2005 at 20:47
Neat job, very professional lookin'.
AnswerID: 137197
Reply By: Des Lexic - Monday, Oct 31, 2005 at 21:24
Eric, I used to have mine mounted against the side wall about where yours is. Occasionally, I'd be talking to others and found I had no response. It turned out that I would change channels with my leg without realising it. It's now mounted in a pod on the dash.
Des
AnswerID: 137204
Follow Up By: Rock Crawler - Tuesday, Nov 01, 2005 at 07:59
Your right on there Des . I did a trial fit as you mentioned and I kept hiting it with my leg , this is why I cut the concole and fitted it inside
FollowupID: 390960
