Site Search
Section Image
Front hubs \ Nissan Patrol
Submitted: Tuesday, Nov 01, 2005 at 02:20
Jambobwana
The swivels on my 1997 Nissan Patrol are corroded and appear to have no grease on them.
I am going to have to strip them down and find out what is going on. Can anyone tell me if they are normally filled with grease or is there an oil reservoir in the hub?
I am new to Nissan's as I have had an old 60 Land Cruiser for the past 10 years. With the Toyota the oil from the diff used to work it's way into the hub and wash the grease out. So I'm asking about the make up of the Nissan... It's new territory for me and I would be grateful to know what the likely cause of my problem is.
Thanks, Jim
Advertisement
ThreadID: 27714 Replies: 5
Views: 1273 FollowUps: 1
AnswerID: 137253   Submitted: Tuesday, Nov 01, 2005 at 07:51
Well 55 replied:
They are the same set up but I don't think there is the plug you can remove to pump in more grease. Undo one of the bolts on the bottom king pin bearing cap and see if anything comes out andnmaybe pump grease in there.
Otherwise a strip down job.
Reply 1 of 5
AnswerID: 137265   Submitted: Tuesday, Nov 01, 2005 at 08:52
Willem replied:
Jim
Best thing would be to strip them down completely. Check all the bearings at the same time.
You might find that the corrosion is due to the vehicle being driven in salt water at some time of its life.
You can do the job yourself if you are so inclined....just time consuming.
Karoo Jackal
Click Image to Enlarge
Willem
There is more than one way to get a rabbit
Reply 2 of 5
AnswerID: 137276   Submitted: Tuesday, Nov 01, 2005 at 09:52
Member - Duncs replied:
Are you just looking at teh outside? My old GQ which had worked pretty hard most of its life had the same "problem" you are talking about.
I have highlighted the word problem because they never were. Across the paddock, up the west coast, Flinders Ranges, NW Victoria, Blue Mountains it was working hard under me too. But I never had a problem with the hubs.
Then before going to Cape York I got talked into a "pre trip check" which was carried out by a well respected specialist 4x4 workshop. "Those hubs look a bit ordinary." says the mechanic. "Well fix them." says I reaching into my pocket a little further.
I set off to Cape York confident that my GQ was in fine shape. Then on the beach at the Pennyfarther river what starts to slip. You guessed it the front hubs.
When I got home I asked around a bit and could not find anyone who had had trouble with the hubs on a GQ. My professionally serviced hubs continued to slip and I eventually replaced them with a pair of dry corroded looking ones from a wreck. Never had a problem again. I regularly checked wheel bearings and had to remove the hubs for that job so I was regularly looking at them. The outside always looked ugly but the inside is what makes them work.
I would have a look at them and keep an eye on them. I would give them a hard time close to home but I would be suprised if they caused a problem.
Now I am not a mechanic and I have not done an exhaustive study of Nisssan hubs but that is my experience, for what its worth.
Duncs
Eric the Emu at home
Content with where I am but looking for somwhere else to go. Pic 1 Eric the Emu at home Pic 2 camped on Cooper Cr
Reply 3 of 5
AnswerID: 137330   Submitted: Tuesday, Nov 01, 2005 at 18:51
Jambobwana replied:
Sounds like I should strip them down just to be safe. I'll need to order a whole lot of new seals I suppose...
Thanks for the feedback, Jim
Reply 4 of 5
FollowupID: 391120   Submitted: Wednesday, Nov 02, 2005 at 14:07
vitara posted:
Where are you located at ?? Regards Vitara
Activities Index
12 Lap EVO Rally Experience + 1 hot lap - NSW 12 Lap EVO Rally Experience + 1 hot lap - NSW
Hunter Valley - NSW
Find out what rally driving is all about as you take a Mitsubishi EVO for 12 laps + 1 hot lap around
Saraswati Ritual - 6.5 hours of me time Saraswati Ritual - 6.5 hours of me time
Townsville Region - QLD
A totally indulgent and new experience. The ultimate indulgence. A full day of pampering.
Calypso-Certified Diving in the Great Barrier Reef Calypso-Certified Diving in the Great Barrier
Cairns and Tropical North QLD - QLD
Experience the wonders of the largest collection of coral reefs in the world!
Book Now - Things To Do
AnswerID: 137446   Submitted: Wednesday, Nov 02, 2005 at 15:00
Truckster (Vic) replied:
If your talking about the large 'balls' that are the swivels inside the discs looking from the front of the truck, they arent ment to have oil/grease on them from the outside - if they do you have a blown seal.. :)
Reply 5 of 5
