AnswerID: 137724 Submitted: Friday, Nov 04, 2005 at 08:15
OMN
replied:
Hi All,
Thanks for all of the positive replies. I took the car to Pirnaha as i was around the corner from them the other day and they supplied me wiht a valve to go in one of the lines.
As you mentioned if this is turned off then you will have some real heating problems with the engine BUT as the
shower gets used only once in a while it is something i am willign to live wiht as redoign all of the plumbing as some have suggested is beyond my capability and means pulling everythgin out.
I tried it last night with the valave and you only have to reduce the flow ever so slightly to g the temp to drop quite substantially.
I also have had the pump rewqired so it can run without the engine running so if for some reaon i simply wanted a
cold shower that can happen now.
I havent swapped the fittigns on the inlet side over yet but will look at doing that in the not too distant future.
The place i had it installed were very good about redoing it all and fixed it up no probelms once the solution was relayed to them and didn't have any hesitation puttign it in for me.
Thanks again to all who replied greatly appreciated.
Mark
Reply 8 of 8
FollowupID: 391372 Submitted:
Friday, Nov 04, 2005 at 08:21
flappa posted:
Good news.
There is another alternative that wouldn't effect the motor if you forget to change the valve , and that would be to put a 2nd
cold water line into the system like I have done , and they do in marine setups.
That way the hot can be as hot as it likes , and you can adjust using
cold water , just like at home.
Works well for me , because I had problems getting the temp right , because I have climate control in my Patrol.
