Turbo
Submitted: Friday, Nov 04, 2005 at 14:53
ThreadID: 27821 Views:2316 Replies:4 FollowUps:2
Good afternoon,
I was wondering how the turbo that run a roller bearing are affected by heat. I thort the shaft was run in white metal bearings cantered by oil pressure.
Can you help?
Reply By: Wizard1 - Friday, Nov 04, 2005 at 15:36
Perhaps a few english lessons wouldn't go astray.......
AnswerID: 137783
Follow Up By: Jimbo - Saturday, Nov 05, 2005 at 19:43
Perhaps a lesson in common decency might help your outlook on life.
That was a cruel comment.
FollowupID: 391579
Reply By: Johnny boy - Friday, Nov 04, 2005 at 16:23
Hi Ross could you please ask what ever you need to ask again , but this time read it before posting because there is alot of peaple who can help but only if we understand what your asking ??
Im not having a go at you mate I just got a little lost reading your post
Regards JB.
AnswerID: 137792
Reply By: Snowy 3.0iTD - Friday, Nov 04, 2005 at 16:50
I must admit that a turbo running on roller bearings is not something I have heard of before, usually they run a hydro-dynamic bearing (turbo shaft floats on a film of force-fed oil). Assuming it is actually running on roller bearings as the metal heats up it expands, due to different shapes and metal/alloy types in the turbo and bearings, at some point a part will expand to the point where it fouls against another, resulting in scoring and damage of that part. After it cools it may be totally stuffed or it may just be an irregular shape or scored, which will also eventually stuff it. Hydro-dynamic bearings would definitely be the better choice for turbos.
AnswerID: 137798
Reply By: awill4x4 - Friday, Nov 04, 2005 at 22:26
Roller bearing turbo's are the weapon of choice in the high performance industry. Their main benefit is the ability to spool up the turbo faster thus allowing a larger turbo than usual therefore increasing airflow and more horsepower. Quite a few of the competition 4x4 guys are now using roller bearing turbo's as they are getting more power and less lag than with the old floating bearing type.
One major problem of the roller bearing turbo's however, is that if it needs a rebuild then generally the whole centre cartridge needs to be replaced rather than just a centre bearing and a couple of seals.
Regards Andrew.
AnswerID: 137859
Follow Up By: Snowy 3.0iTD - Saturday, Nov 05, 2005 at 15:16
Thanks for the info awill4x4, I stand corrected and admit ignorance on this one. A quick Google search yielded some interesting reading on the subject.
Regards Snowy
FollowupID: 391559
