*03 2 wd low range
Submitted: Friday, Nov 04, 2005 at 16:56
ThreadID: 27829 Views:3324 Replies:9 FollowUps:3
Hi Folks
Some where I read that a wire could be cut so that low range could be selected without the auto lock up of the centre diff. That way low range rear wheel drive is able to be used to pull heavy boats up the ramps.
Any info will be of help
Ray
Reply By: Scubaroo - Friday, Nov 04, 2005 at 17:18
You might want to be a little more specific - such as what vehicle you're talking about.
AnswerID: 137810
Follow Up By: Kiwi Ray - Friday, Nov 04, 2005 at 17:26
Sorry, Trying to do too many things at one time
!994 80# L/Cruiser constant 4 wheel drive Manual 5 speed
Ray
FollowupID: 391432
Follow Up By: Member - DOZER- Saturday, Nov 05, 2005 at 20:07
Ray
www.lcool.org, under technical section....the wire is in the passenger footwell, and makes lockup manual off the dash.
Another way is to remove one plug off the transfer case, just above the rear tailshaft at the 1 oclock position. just disconnect and try it....that is all you really need to do if u have a manual (autos shift smoother in low range, and disconnecting this plug doesnt tell the computer u r in low)
Whilst this is good for hard surface manouvering, you will need to be careful where you use it....the front diff on the 80 (and 100) doesnt like power in reverse at all. Having said that, i have done this years ago, and dont have a problem steering my caravan up my driveway.....(the hitch is on the front bar)
FollowupID: 391582
Reply By: MichaelR - Friday, Nov 04, 2005 at 17:25
Ray,
I'd be very careful using 2WD low range. The torque is effectively doubled on the rear transmission and it is likely something will break. There should be little problem with windup if the car is only used over a short distance in 4WD.
AnswerID: 137814
Reply By: robak (QLD) - Friday, Nov 04, 2005 at 17:48
I don't know anything about this, so I could be totally off the track here, but since your car has constant 4wd wouldn't it be better to keep it in 4WD and just find a way do unlock the centre diff. (ie. cut the wire that sends the signal to lock the diff?).
R.
AnswerID: 137820
Reply By: Kiwi Ray - Friday, Nov 04, 2005 at 18:39
Hi Robak
You are right that is the better way to go.
That is actually what Imeant, but long hours and not much sleep ........ result brain not talking to fingers when typing
No work tonite so will catch up on the Zs
Ray
AnswerID: 137830
Reply By: atoyot - Friday, Nov 04, 2005 at 21:25
There's a 2 wire (I think) connector underneath near the g/box. You just need to disconnect it and tape it up. All you then have to do is remember that you've disable the auto-difflock on low. Try here for the how to. I've done this on my 100 without any problems,
regards,
AnswerID: 137853
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Nov 05, 2005 at 01:51
It will have no worries having it in low 4 to launch boats - despite what nissan owners will try and tell you the drivelines just arnt that weak - several times i have had the ute dropped off to me still in 4wd after 18k of bitumen driving
AnswerID: 137883
Reply By: Ray Bates - Saturday, Nov 05, 2005 at 09:35
You might want to try:- "80 Series Cruiser Owners OnLine" at http://reality.sgl.com/80_series
This will explain everything for you
AnswerID: 137900
Follow Up By: Ray Bates - Saturday, Nov 05, 2005 at 10:18
Hi I tried that web page that I mentioned but it would not download. Try this:- go to Google, put in 80 Series Owners OnLine, when the page has loaded go to Technical
FollowupID: 391528
Reply By: geocacher (djcache) - Saturday, Nov 05, 2005 at 13:15
Transmission wind up (or what ever it's called this week) occurs due to difference in the number of revolutions done by each wheel as the vehicle corners on surfaces that don't allow tyres to break traction. It is worse if the corners turned are all in the same direction, as turning the opposite direction unloads the stresses the previous corner may have induced.
Engaging low 4wd to pull a boat out of water (as I do) in a straight line up a dry boat ramp is not going to cause any problem at all ever. On a wet boat ramp you could drive up a course of witches hats coming up the ramp no problem. Even in the dry probably cos the opposing cornering wouldn't be an issue anyway.
Talking to some of the CFA mechanics and they've seen 4wds driven to back up crews over astounding distances when left in 4wd on bitumen roads with out problems.
Over short distances on dry bitumen I'd very much doubt you'd ever encounter a problem even if you were turning into car parks or what ever.
I don't know who recommended it too you but it sounds like one of those things that one person did and it snow balled cos someone thought it sounded plausible that it was a good idea.
Don't muck around with it. Leave it the way it is.
AnswerID: 137913
Reply By: Kiwi Ray - Sunday, Nov 06, 2005 at 11:35
Thanks for all the help
Ray
AnswerID: 138034
