Second fuel tank problem
Submitted: Saturday, Nov 05, 2005 at 07:41
ThreadID: 27837 Views:2330 Replies:5 FollowUps:1
G'day folks. I have a 1985 60 series diesel with an auxiliary tank (45litres). It runs on one tank or the other, ie, the secind tank doesn't pump back into the main tamk as some systems do. If I run either tank dry before changing over, it air locks and I have to bleed the system before proceeding. This means if I din;t have to fiddle around with a roadsise stop, I always have to leave about 5-10 litres still in the tank when I change over as the guage just isn't accurate enough to let me change over just before the tank is empty. Kind of negates the advantages of carrying that extra fuel.
Anyone else have this problem? Does anyone have a solution? Can a pump be fitted to transfer the spare tank contents back into the main tank?
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Nov 05, 2005 at 11:32
The camper i used to have had a 65l main and 90 litre sub. It had an electric fuel pump that transferred fuel from the sub to the main. but the problem you speak of is part of life. I usually try and avoid running a tank out because unlike a 2h a 1hz relys on the fuel for lubrication and it can get expensive running tanks dry
AnswerID: 137906
Reply By: Peter 2 - Saturday, Nov 05, 2005 at 12:58
The best way with any diesel unless it is a factory system is to run on the main all the time and use a pump to transfer from the auxilary to the main.
Any air in a 2H (your 60 series) will stop it and require priming and bleeding to get it going again.
1HZ (post 1990) cruiser diesels will self bleed but you WILL stuff the injector pump as it relies on the fuel to lubricate and cool it. Running it dry even when changing tanks as the engine starts to miss will lead to pump failure eventually, the first sign of which is slow to start when hot.
I've use those inline Whale plastic pumps used for water tanks as they are rated for diesel fuel transfer. Just put the pump in the pickup line and tee it into the breather on the main tank filler neck or fit another fitting in the filler neck.
AnswerID: 137911
Reply By: Bilbo - Sunday, Nov 06, 2005 at 16:37
I made my own long range tank to fit under the back of a trayback Maverick ute. I used a Repco electric fuel pump to pump diesel from the LR tank to the main tank in the front. Repco fuel pump was about $55.00 but that was a fair few years ago.
An in-line (suction side) fuel fliter was fitted (one of those small Ryco ones with two nozzles on 'em) and it only blocked once when sucking all the crud from fabrication etc.
If the LR tank is smaller than the main tank, simply use the mian tank until there is sufficient room in the main tank to transfer the LR tnak into the main tank. The Repco pump is a small piston pump and will transfer about 80 litres in 3/4 of an hour. Just keep drving and watch yer fuel guage go up instead of down!!
The pump is reasonably quiet when pumping but rattles like buggery when it runs dry. You'll soon know when the LR tank is empty!
The LR tank came out of an old Valiant Charger (very flat, but large capacity), plus the Repco pump, bit of cable, a switch and some fuel piping. Total cost for an 85 litre tank? - about $100.00.
Piping layout is as mentioned in previous message - simple.
Bilbo
AnswerID: 138068
Reply By: mfewster - Sunday, Nov 06, 2005 at 20:45
Bilbo, Peter 2 and Davoe. Many thanks everyone for your assistance. Just brilliant!!
I will have a go at making something up to fit. Anyone have any thoughts on the Repco pump versus the Whale pump?
AnswerID: 138114
Follow Up By: Well 55 - Monday, Nov 07, 2005 at 08:13
One other way is to plumb the breather hose from the main into the aux, and have a breather on the aux.
As the fuel in the main drops it sucks fuel out of the aux using the breather of the aux.
Not hard to do,the gauge stays on full until the aux is mt the drops as per normal.
FollowupID: 391807
Reply By: mfewster - Monday, Nov 07, 2005 at 18:58
Thanks well55. That is really neat. Has anyone else tried this appoach?
AnswerID: 138293
