PC installation in Car
Submitted: Monday, Nov 07, 2005 at 10:41
chump_boy
This is just a bit of a random thought, but it may lead somewhere yet.
Has anyone on this site installed a PC in their vehicle? Not a laptop, but a permanantly mounted PC.
I have been thinking for a little while if this may be worthwhile doing. Probably not, but I am a network engineer by trade, so I am always tinkering with PC's.
What I am thinking is a touchscreen mounted in the dash, a decent sound card to run the car stero, GPS builtin, DVD player for the kids (seperate monitor in the back), and a decent video card. Wireless card for internet where possible (I think McDonalds all have wireless access now) and network connection at home, and mabey a little war driving...hehe...., USB ports for digital camera, reversing camera, MP3 player, etc....
Anyone else have any ideas or thoughts? I know it would be possible, but I wonder if it would be worth it?
Chump
Reply By: Truckster (Vic) - Monday, Nov 07, 2005 at 10:46
There are companies that make them already... but they aint cheap.
138204
Follow Up By: chump_boy - Monday, Nov 07, 2005 at 10:51
Yup - I've seen them. They slot into the DIN slot in the dash, and you go from there. And yup, they aren't cheap.
I'm looking at a home brew affair, made with cheap parts (ie..easily replaceable).
It would be fairly easy to run some flavour of Linux on it to get it all to work, and make sure it didn't need a re-boot all the time...lol
391846
Reply By: myfourby - Monday, Nov 07, 2005 at 10:54
The reason most people use laptops in vehicles (apart from their size) is that they are generally more rugged and designed for portability.
I am also a network engineer - and had the same question posed to me by a mate who recently setup his patrol with in-car Nav - DVD etc... - He was
well on the track of installing a full PC in
the gap where the passenger airbag sits (when installed!). I managed to talk him out of it - and he never looked back. A laptop is more designed for vibrations/dust and the rough and tumble that will be required of if when installed in a 4WD. The other good thing is that it can still be used as a PC outside of the car - and you can still watch DVD's in the tent while in bed (if you so desire!). Of course - they are more expensive - but - you get what you pay for.
I personally don't think installing any type of computer in the car is "worth it" - I go away on the weekend to get away from computers. However if you have a passion for it – that’s what it is "a passion" - so do it - but be aware that the hardware you intend on using is really not designed for the application you are proposing for it - and is therefore more prone to failure.
-myfourby
138206
Follow Up By: chump_boy - Monday, Nov 07, 2005 at 11:03
lol....it is just one of those "why the hell not" questions, thats all...
I'll probably never get around to it anyway.....
Chump
391850
Reply By: Sand Man (SA) - Monday, Nov 07, 2005 at 10:56
The beauty about a Laptop is not so much the portability and compact size, but the robustness of its design, especially the hard disk drive.
Mate, where do you mount the tower???
The laptop sits nicely in the
well under the front
seat and you can still use your touchscreen mounted where ever it's convenient.
Then when you want to do some serious work with the PC, as in downloading photos, etc. then you can take it out and sit it on the
camp table.
138208
Follow Up By: Truckster (Vic) - Monday, Nov 07, 2005 at 11:10
When you rip open a case of a computer you realise how much wasted space there is..
Look at small form factor Dells and others, they take up the same footprint as a laptop, but are still 4inches high due to the power supply.. But if making your own case to house the computer in, you could really make it S M A L L and thin.
Get a motherboard with onboard everything, video, sound etc, and theres no real need for any thing much else, the biggest thing would be the CPU and cooling fan for that. Kybosh the floppy, and your 1/2 way there. :)
391852
Follow Up By: signman - Monday, Nov 07, 2005 at 13:31
G'day Sandman
When you stick your lappy under the front
seat, do you leave it in a soft case?? Under off road conditions- how would it go with endless corrugations, bouncing over
sand dunes etc?? Do you sit it on foam?? If it's not in a case- how would it go with dusty conditions??
If its running with ,say, OziExplorer it would be accessing the HDD some of the time?? Any problems with heads crashing??
It's just that I have been thinking about it for a while- but can't convince myself I wouldn't be doing the lappy any good.
Your comments and advise are welcome.
391895
Follow Up By: Sand Man (SA) - Monday, Nov 07, 2005 at 14:21
signman,
I just place
mine under the Driver's
seat on nothing but the carpet.
Dusty conditions? I usually keep positive pressure inside the vehicle from the air con/fan assembly so very little dust enters that I have noticed.
In my opinion, the laptop computer is built to handle the rough stuff.
Haven't had any trouble with the hard drive.
I don't treat the lappy with kid's gloves either. I have an IBM Thinkpad and have recently "upgraded" to a Dell Inspiron, however I'm still using the Thinkpad on the go at present.
391908
Reply By: TerraFirma - Monday, Nov 07, 2005 at 11:36
I think a PC is a waste of time, go with the Laptop. A PC needs 240v all the time whereas the laptop has a battery and is built for this task. You then gotta ask yourself how useable will a PC be as a DVD player in a car, not much, you want wireless headphone capability and the like.
138222
Follow Up By: myfourby - Monday, Nov 07, 2005 at 12:45
Not true - PC's require 12V and 5V supply - the 240V power supply on PC's is only used to drop the voltage - you would therefore not need the 240V powersupply for a car install - a voltage regualted powersupply (12V and 5V) is all that is needed here.
-myfourby
391884
Reply By: The Explorer - Monday, Nov 07, 2005 at 12:09
Check this out (and other threads)
In Car PC
138230
Reply By: Member - t0me (WA) - Monday, Nov 07, 2005 at 14:21
The power supply on the PC does more than just drop the voltage, it also "cleans" it, providing some protection and clean power. You can't just plug it into 12v, it don't work.
The other advantage of a laptop over a pc in the car is that it has everything on the one board, so card's don't come out of slots.
The take up a lot less room too.
The battery on the laptop gives you a buffer for when the power is off for a bit.
You can get a special powersupply for your car for a normal pc but they are expensive (I think the company is in USA). More efficient than a normal one with inverter.
The ideal solution I thought is an old laptop with a duff screen that you can pickup cheap.... (at least thats what I thought, but that old laptop's been sitting on the "to-do" list for a looooong time, must remember to stick that on ebay sometime...).
I love my PDA (XDA IIi) and use that, got all the GPS apps I need, wifi when its available, and a camera suitable for quick snaps (and thats always in my pocket anyway). It cost more than the GDP of some small African nations but I'd feel lost without it.
138257
Reply By: Member -Dodger - Monday, Nov 07, 2005 at 16:00
Personally I use my laptop for all of the above running it off the 300w pure sine wave inverter however you can now get an adapter that will plug into your cig lighter that will give up to 20v DC at 6amps for around $150.
I would go the laptop as it can be moved from your vehicle to any other vehicle as
well as in the tent or van plus the kids or anybody can watch dvd's.
When we did the
Hay River trip at one
camp the ladies watched Desperate Houswives which was downloaded from the net previously.
138266
Follow Up By: flappa - Monday, Nov 07, 2005 at 16:07
OOOH , that would be a tad illegal wouldn't it . . .
lol . . .
We have a few Simpsons episodes.
I like the portability of the lappy more then what it can actually do.
391915
Reply By: Woobla (WA) - Monday, Nov 07, 2005 at 18:43
Hi Chump,
Thought you may be interested in my pc.
I havent had it out on too much dirt and corrugations yet, so how it performs is yet to be known.
It has a windows 98 pc, DVD, TV,GPS, Mp3, and a phone if you want.
I will let you know how it goes when we get back from the Michell Plateau.
Jeff!MPG:3!!MPG:4!
138288
Reply By: Member - John (Vic) - Monday, Nov 07, 2005 at 18:53
I am currently using a laptop for all the usual reasons.
But I am now looking to do just what you are talking about, Have a look here
http://www.bitdistribution.com.au/?stg=49
These guys sell Automotive PC's and touch screen's,
well worth the look.
And by the way the components are the same stuff used in laptop's so hard drives etc are as robust as any laptop would be.
138291
Follow Up By: Jayk - Tuesday, Nov 08, 2005 at 00:51
I got a bit excited about this option too. However, it looks as though you buy a very bare bones system that needs a HDD, RAM, CD/DVD drive etc added to make it usable. Also, I'm not sure that they come with a processor. The specs are a bit confusing on that point.
By the time you add the basics to get a usable systme, the cost rapidly reaches the price of a reasonable laptop, which, as a lot of posts already suggest, gives you lots of versatility and robustness.
391997
Reply By: wresat - Tuesday, Nov 08, 2005 at 06:49
Have not yet got one of these yet, still doing research on the subject, but this is a good link to a site in the US
http://www.short-circuit.com/categories/boards.html
Do a search for “VIA EPIA MII”. These are small 17cm x 17cm motherboards. Just like the real thing except smaller. Can get these for $250 aussie dollars with built in CPU, power supply $100, just need to add 2.5”HDD and suitable case. Another link to a heap of these boards
http://www.epiacenter.com/modules.php?name=Content&pa=showpage&pid=39
Still trying to decide which way to go, laptop or permanent setup! Maybe permanent
138391
Reply By: Member - Troll 81 (QLD) - Tuesday, Nov 08, 2005 at 07:55
I have been following this post and the other one from last week or the week before. I am going to be doing the same in my Patrol, mainly for navigation. Going to run the screen in the second din slot and the lappy under the
seat. It will just be cool to download the videos from the day straight onto the lappy when we sit around the fire and we are not doing much that way it's already done. I think if you already have a lappy you might as
well use that....it's allot cheaper coz all you need is the touch screen or am I missing something?
138395
Reply By: Mirek - Tuesday, Nov 08, 2005 at 10:05
Hi Chump,
I have installed "In Vehicle Navigation and Entertainment system" - NavNet with the 7 " VGA touch screen in my Prado several months ago. This small PC is designed by Australian company for "OFF Road conditions". With NavNet I have GPS - Street to Streeet Voice navigation, OzyExplorer (moving maps) with all Digital maps of Australia and 4x4 tracks, DVD, CD player, Video, Mp3 and Mp4,Reverse camera, LAN with
my Home PC, wireless internet, USB port for digital camera and much more.
NavNet is easy to use and NavNet software is designed for easy access to the most popular applications installed on the NavNet in Vehicle Navigation and Entertainment System. I can listen my music while GPS is giving me all directions
(visual and audio) watch DVD and etc.
Have a look on this web : www. dmck.org/git
It was the best investment for my 4x4 .
Mirek
138417
Reply By: geoffliz - Tuesday, Nov 08, 2005 at 14:31
I have just installed a car pc in my Rodeo. Got the PC from
The PC is the same height and width of a car radio and about 2 inches longer so it will fit in most dash boards.
PC runs win xp, has 80Gig harddrive, DVD, 2ghz processor, etc (It's better than
my home pc) and runs on 12volt. Cost $1100
Also got a 8" touchscreen monitor of Ebay that can also be used as a tv (in built tuner) and has connections for a reversing camera as
well $300.
For sound I am using an FM transmitter connected to the headphone socket on the PC and just tune the car radio in.
I already had a GPS which is connected to the pc via the com port
Personally I am very happy with the result and for the cost (about the same as a home pc) consider this the best way to go for in car DVD, navigation, photos, video, music, reversing camera, diary, contacts, games, office docs, games and much more.
With a wireless network to home pc I can surf the net and update programs from the garage as
well as transfer photos, etc to the home pc.
It's amazing that car pc's are not more common ( I'm sure they will be soon enough).
In relation to using a laptop. Before I found this unit I had considered this but was put of by the room taken up by a laptop. I was even considering a ceiling mount but found that this blocked half the windscreen.
Cheers Geoff
138454
Reply By: Rokkitt - Tuesday, Nov 08, 2005 at 18:13
Now
where to start, check out some of the available systems available on the internet right now - as simple drop in "DIN" size units. I have also found many deviations from this design - from cases that look like real cases to small form factor cases that resemble amplifiers.
The HDD is not a problem as these systems generally utilise laptop drives anyway - Compact flash is another way to do this - using something called a Ramdrive totally eliminating issues with vibration.
Now regarding the power supply - you will also find off the shelf PCB's specifically designed to run the computer within the car, even overcoming voltage drops when the car starts and offering battery low voltage monitoring.
I can't think of a reason these systems are not more popular with the many possible uses including: Hands free for your mobile, Internet access via GPRS, GPS and Sat Nav, Entertainment including Radio and TV, Email, Office Applications, you can even monitor your cars ECU for faults etc....they can connect to any number of camera's and even record the images, you can view digital images and edit them in the car - then follow up by sending them off as soon as you have reception.
I could go on but instead I will leave a few links and let you decide for yourself. By the way I am a Computer Hardware Engineer with one of these systems fitted to my 4WD which does many
miles of hard 4wd'ing.
link text
link text
link text
Rod
138498
Follow Up By: Rokkitt - Tuesday, Nov 08, 2005 at 18:17
Try those links again:
stevieg
Rokkitt's PC's
link text
392121
Reply By: Member - gujimbo - Tuesday, Nov 08, 2005 at 22:41
Greetings
I went through the same process about 12 months ago , i finally built my own
system based on a VIA Epia-m motherboard , a 40gb laptop harddisk and a 7"
Lilliput touch screen , the system runs under WIN xp and i use Ozieexplorer for mapping.
A few pics are shown on my rig profile
jim
138562
