80 series drivetrain clunking.
Submitted: Monday, Nov 07, 2005 at 18:50
Big Woody
I have an 80 series GXL constant 4wd 5 speed mannual wagon. There seems to be excessive backlash either in the centre diff or maybe the transfer case. It is difficult to change gears smoothly and if you tap the throttle on and off the clunking is pretty bad in both directions.
Can anyone tell me if this is common?
Where is the problem most likely to be?
Is it a simple or complex fix?
My cruiser has done a fair bit of heavy towing in it's life but has been very
well maintained.
Thanks,
Brett
Reply By: Brad, W.A. - Monday, Nov 07, 2005 at 19:34
Brett, i have a 95 80 series 4.5L auto and it has the same clunk every now nd then. In the autos it is apparently worse than the manuals. I have spoken to a 4x4 mechanic about this and it is common on the 80 series, as to a fix i don't know.
Brad.
138298
Reply By: Wayne (NSW) - Monday, Nov 07, 2005 at 19:46
Brett,
Have a look at the uni's. Also the play in the spline of the front and rear tail shaft. These will have to be removed to check properly.
Wayne
138300
Follow Up By: Big Woody - Monday, Nov 07, 2005 at 21:50
Thanks Wayne,
I have checked these on the ground with everything in neutral, but as you say, I will have to remove to check properly.
Brett
391967
Reply By: Member - DOZER- Monday, Nov 07, 2005 at 20:04
Hi Brett
The most common cause of excess backlash is the front c/v joints and more correctly, the drive plates that the c/v drives on the outside of the hub.
To check them, you only need to remove the dust caps in the middle of the front
wheels and look for movement forward and bakward in the spline of each.
When this wear gets bad enough, drive will be lost altogether.
Now, the 80 series constants were never too good with backlash, so use this as a guide only...they might be ok
Manuals are far worse than autos, as autos always keep the torque forward when changing gears....when you change gears in manuals, you can sometimes let off to early and get the backlash wip happening.....
Check out the tech pages of this site
www.lcool.org
138306
Follow Up By: Big Woody - Monday, Nov 07, 2005 at 21:49
Thanks Dozer,
This is where I will start looking.
Brett
391966
Follow Up By: Member - Bill S (NSW) - Thursday, Nov 10, 2005 at 21:19
Just a note, Recently or 12 months ago my daughters 80srs gxl constant 4x4 man was brought to me for diagnoses of a CLUNK.This turned out to be a stuffed C/V joint in the R/H front. Very strange to diagnose as the vehicle would drive in low range no noise but hi range it sounded like centrediff or the transfer case or front diff was buggered.In the workshop {not
mine} transfer case was the first dismantled [no problem] thel moved to the front diff but on dismanteling the front C/v joint it was discovered bleep tered C/V so check them first???
Regards BILLS
392635
Reply By: streeter - Monday, Nov 07, 2005 at 20:16
i have a 92 model with the same sort of noise i am geting the cv jionts done on thursday and new hubs i will let you know if it is fixed on friday
geoff
138311
Follow Up By: Big Woody - Monday, Nov 07, 2005 at 21:43
I will watch for your reply with interest Geoff.
391961
Reply By: techo2oz - Monday, Nov 07, 2005 at 21:25
G'day Big Woody,
I have a '92 model 80. I have a similar noise and the symptoms are the same, rapid jabs on and off the throttle induces loud scary sounding clunks.
I went to a number of transmission and driveline "specialists" and they all insisted this was normal for the fulltime 4wd especially in the cruisers. It is backlash in the front diff which is the cause. The backlash can be removed, however what it then does is wind up the front diff to a point where it will want to keep driving in a straight line. (not too sure of the full technical blurb) but apparently when going in a straight line, the slack is not important as both front
wheels are travelling at the same speed in the same direction.
Now, when cornering, and the tighter the corner the bigger the affect, the
wheels are turning at different rates. Again Diffs are designed for this, but apparently there needs to be a little give somewhere to allow for the marginal difference in rotational speeds. Without the give, the diff would want to keep driving the wjeels at the same speed and hence force the car to want to keep going in a straight line.
This all may be just a lot of
well rehearsed waffle, but as it has been repeated in much the same words on 3 different occasions by 3 independant 'spurts, I have a tendancy to go along with it. When I asked if it was something I should be worried about, the unequivocable response was nah mate, I've heard worse than this and it still wasn't a problem. Which keeps catching me by surprise because my concern over being stranded can quite easily be converted to easy cash by them.
This was all 40,000 k's ago and the clunks are still there, no worse and no better. Am interested in others experiences though as I would hate to be misinformed and be out in the middle of no-where with something broken and the prospect of expensive towing.
138328
Follow Up By: Big Woody - Monday, Nov 07, 2005 at 21:48
Hi Peter,
I have 5 brothers, 4 with 80 series cruisers and 1 with a 100 series. Hows that for a family?
Although
mine is the oldest it has actually got nearly the lowest K's on the clock. None of my brothers cruisers clunk like this one does.
As mentioned above I may look at hubs, uni joints and splines first as they are all an easy fix. If that is unsuccessful, I will have to dig deeper.
Brett
391965
Follow Up By: Redback - Monday, Nov 07, 2005 at 22:26
Now thats a funny family, all cruiser owners, some people never learn.
391973
Follow Up By: fatz - Tuesday, Nov 08, 2005 at 07:56
now now - Redback, do you want me to start...His family have got great taste..
392007
Follow Up By: Big Woody - Tuesday, Nov 08, 2005 at 07:59
Actually our Dad died about 4 years ago and guess what he had?????.............................................Yes, an 80 series too!!!!
Christmas time was like a 4wd club meeting.
392008
Reply By: prado_95 - Monday, Nov 07, 2005 at 22:47
driveline lash is common on most full time 4wd vehicles when they have done some km. Centre diff seems to be a large component.
Mine even has it on a part time 4wd system, but it has done a 'few' km now.
dave
138350
Reply By: streeter - Thursday, Nov 10, 2005 at 20:39
how u doing brett
i have had the work done [ c.v joints front hubs wheel bearings swivel housings and replace front drive flanges] a lot of work and cost me $1400 Im happy and some what relieved to say its fixed its always a worry to pay so much money and its no better. Im heading to the otway rangers in the morning to give it a good test theirs been plenty of rain down this way im in warrnambool [vic] hope ive been a bit of help to you
geoff
138865
Follow Up By: Big Woody - Thursday, Nov 10, 2005 at 22:08
Thanks Geoff,
Yes you have been very helpful. I had new kits put in the front swivel hubs about 8 weeks ago but it looks like I may have to go a bit deeper. Have fun in the Ranges this weekend. I love that part of the country. I am now officially jealous.
Brett
392643
