False floor in Rodeo
Submitted: Monday, Nov 07, 2005 at 20:14
pafc
Picking up my new Rodeo 28th Nov. I want to build a false floor about wheel tub height, I want to build it out of square tube with a ply top covered with carpet, but can't weld, any suggestions regarding joiners. I built 1 previously with plastic joiners which failed.
Thanks for your help.
Reply By: Ray Bates - Monday, Nov 07, 2005 at 20:45
I have a false floor in my cruiser. I made
mine out of MDF and used light galvanized angle for the joints but I also have a cargo barrier that the false floor is secured to. If your Rodeo is the type of vehicle with "dicky seats" in the back the anchor points for these seats can be used as
well
138317
Follow Up By: Utemad - Monday, Nov 07, 2005 at 21:01
The Rodeo is a ute. No dicky seats there. However I have mounted my fridge where the backseat (dualcab) used to be.
I never got around to making a false floor but I was always 'planning' to.
391957
Reply By: Ray Bates - Monday, Nov 07, 2005 at 22:13
Sorryabout the info. I got confused with the Jackaroo. If you have a ute I would not use mdf as it is not waterproof
138337
Reply By: Russel & Mary - Monday, Nov 07, 2005 at 23:28
Hi pafc, last year we made a false floor and storage drawers for a Rodeo ute. We used 3/4" angle iron and used the top of the wheel arch as the starting point.Tek screwed the angle on. No welding, just various lengths around the inside of
the tub and a full length piece across the back with a middle support at the back. Also a piece of 1 1/2" wide angle in the middle front to back. We folded up a couple of drawers out of zincalume sheet with slight criss-cross fold on the sides for stability.Made rollers out of alternator bearings from the auto elec. bloke and run them in the grooves in the floor. Two pieces of marine ply for the top covered in boat carpet, and plywood fronts bolted to the drawer fronts. Rope pull handles with a bit of garden hose to hold and knots on the inside. The marine ply tops were gutter bolted down and it was a tight squeeze underneath with a spanner(I am 105 kgs!!!) but it got done. It cost all up $450 not including any labour, which you don't anyway when you build something for yourself. It's done a 4 month trip from SA to
Exmouth and back with no design faults. Rus.
138360
Reply By: sudsy - Tuesday, Nov 08, 2005 at 22:10
Gday pacf.
I'm pretty sure I've seen cast aluminium and steel joiners in some hardware shops.
They knock in tight and you can tek screw or rivet them in for extra security.
Good luck
138546
