Friday, Nov 11, 2005 at 09:00
What about depth of tread in your calcs.
Most new tyres I have seen have 9 to 13mm of tread, some MTs more.
Coopers being one that offers extra tread depth.
They may have to look at offering less tread depth to stay legal :-)
I think this is getting all too hard.
Pump your tyres up hard and you most probably gain 5mm over standard road pressure.
Let them down to 20 psi and you must loose about 15mm.
Will the authorities confirm at what tyre pressure these measurements are done at if it is the true dimension?
I think it has to be worked on tyre placard size, rather than actual size.
Could be a few stretched tape measures otherwise :-)
"Really officer, my 285/75 16 tyre are under 32" OD, look what my tape measure shows!" And measure on
the spot.
392731
