AnswerID: 676 Submitted: Sunday, Jun 24, 2001 at 00:00
Andrew Stephens
replied:
I felt that I had to put in a plug for the Garmin
GPS II+. I have had this unit for about 12 months now and I am still finding more uses for it. I agree with the previous post about the OziExplorer software, great stuff. You can also get the AUSLIG full set of maps for < $100 now, so that is even better. The advantage with the
GPS II+ is that the screen can be rotated, so that the unit is horizontal or vertical. The unit is wedge shaped so that it will go deeper down on the dash. The antenna is very good, and you will only get slightly better performance from an external antenna ( I have done tests with a friend ). It is also water proof, although larger than the e-trex, but I think that the screen is larger as well. I purchased mine from the U.S. at the worst of our Aussie dollar slide, and it was still $200 cheaper, so make sure that you
shop around.
All that being said, they are all much the same, with the same features, it is mostly a cosmetic issue these days. Do a
search for some comparisons. Also have a look here: http://www.gpsoz.com.au/
Cheers, and good luck, Andrew.
Reply 7 of 8
