HF in an 80 series - wheres yours?
Submitted: Monday, Nov 14, 2005 at 22:04
Member - Davoe (Widgiemooltha)
With any luck i will have a Barret 250 sitting at the
post office when i come on break. Next trick will be to fit it, I have seen 100 series with them under the passenger
seat but I am unsure if it will fit with the 80 - Any other ideas?
Reply By: MichaelR - Monday, Nov 14, 2005 at 22:10
Have a Codan in an 80. Box goes on the cargo barrier in front of the Engel. Welded a bracket onto the rear wheel carrier to carry the aeriel. Works
well
139406
Reply By: Member- Rox (WA) - Monday, Nov 14, 2005 at 22:25
Same as previous post, Wouldn't rwecomend putting it under the
seat due to sand & Dirt.
139409
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 22:38
My only concern was that it would be subject to alot more vibration on the cargo barrier. Another thought was on the cargo barrier behind the back
seat (again room could be an issue) Hidden and hard to remove would be a decided advantage for a vehicle that gets left under a carport out the back 2 weeks out of 3
393113
Follow Up By: The Explorer - Monday, Nov 14, 2005 at 23:15
Hello - arent they sealed enough from "dust and sand" (
well Codans are) - can understand
water getting in but nothing else to the extent that it would be a problem. Use to mount ours on the side of rear storage area in 80s (just below window), not ideal and in view so not Davoe's preffered choice. Cant think of any options besides those suggested - either up in view or down out of sight but greater potential to get wet - how deep are the rivers out at Kal:)
393122
Follow Up By: mowing - Monday, Nov 14, 2005 at 23:25
Davoe,I have a Codan 7727 (an oldie but a goodie) and I have placed this on the cargo barrier but made up a wooden box frame at both sides and joined these together. That way top and bottom on the unit is protected. I have also included foam inside the box section so that the unit actually rests against the foam and this helps with the vibrations. The sides on the unit are open. Bit hard to explain but if you need any further clarification let me know.
Mark
393125
Reply By: Footloose - Monday, Nov 14, 2005 at 22:39
Depends on whether it's a remote head or a local. Local have to go in the front with you somewhere, they're difficult. Remote usually has head where you can see it and the box in the rear or hung from the cargo barrier....you do have one don't you ? Aerials are either whips or autotunes. Whips are often mounted on the bullbar in the eastern states anyway. Autotunes are usually mounted on the rear for legal reasons....that's not where they work best but oh
If you mount the box under a
seat not only do you get all the dust etc all over it, but also run the risk of drownding it if you find a hole that's deeper than you thought.
139413
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 23:07
Barret 250 is remote head jobbie. Ariel will be whip on the roobar so I dont forget to take it off for bush tracks, deepest
water crossing I get to do in the goldfields at the moment is when i wash the car but the cargo barrier seems to be getting all the votes at the moment although this will lead to running the cable forward for the remote head - Do you rip up your vinyal and put it underneath??
393119
Reply By: Ray Bates - Monday, Nov 14, 2005 at 22:42
I have an 80 series that had a double DIN radio. I had this radio remove and had a CD/radio installed. My HV radio sits in the same hole under the CD/radio. They must both be single DIN to fit.
139414
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 23:09
I have a single tape deck in that hole and have rigged a stash tray underneath it which i find quite handy. I was thinking of putting the remote head on the tunnel in front of the
seat and behind the gear lever
393120
Reply By: Neil & Lynne - Monday, Nov 14, 2005 at 23:23
For your info...we have had a Barret mounted under the passenger
seat of our '98 80 series for about 5 years now without a hiccup at all.
The head is on the centre console in front ot of the shift levers which is very accessible and the auto-tune is mounted on the spare wheel carrier between the wheel & the body.
If you are interested give me a email address & i'll shoot off a couple piccies.
Neil.
139423
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 23:29
do you mean in front of the levers eg between the levers and the dash or the other front between the levers and the
seat? d.evan@mopl.com.au
393126
Follow Up By: Neil & Lynne - Monday, Nov 14, 2005 at 23:31
I forgot to mention Davo, unless you are only intending to use the Barret while stationary I would suggest putting the supplied whip away and keeping it for a backup. Buy the replacement whip which is 3 or 4 times stronger & can be left installed for all but low tree traversing. (not a lot of that in the goldfields lol).
Well worth the $90 cost.
Neil.
393128
Follow Up By: Neil & Lynne - Monday, Nov 14, 2005 at 23:40
Just tried that email address Davoe....it bounced back.
Neil
393132
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 23:43
The ariel i will be buying is a vks multitap and the radio doesnt come with an antenae. I intend to have the ariel removed most of the time as even with the spring bases they still snap. There is actually nearly all low tree territory in the fields as we have 16% of australias eucalypts in the region. For work we would only put the ariels on when needed as they just wouldnt survive
393133
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Nov 14, 2005 at 23:45
yep try d.evans@mopl.com.au
forgot the SSSSSSSSSSSSSSSSSSSSS
TA
393134
Reply By: Voxson (Adelaide) - Tuesday, Nov 15, 2005 at 07:54
I mounted
mine on the back of the centre console...
139439
Reply By: VK3CAT - Tuesday, Nov 15, 2005 at 13:34
Davoe, I have my Codan 8558 under the passenger
seat with a remote head around the altimiter etc. Previous to that I had an amateur HF box in the same location. Not an issue with dust & dirt. Mounting on the cargo barrier seemed to me to make it more vulnerable to damage from items inside the car. Also consider cable
routes etc. my cabling runs through the chassis rails where possible or the trims etc.
RF earthing is most important - antenna, radio & head. Torriodal cores or ferrite beads around cables entering the radio can help with RF feedback etc.
I have some pictures of my setup at
http://www.qsl.net/vk3cat in the mobile page.
Cheers Tony.
139482
Reply By: BenSpoon - Tuesday, Nov 15, 2005 at 16:11
Davoe- I stuck
mine between the inside trim and rear quarter panel in the boot. My only concern is that on a
water crossing, If I
park in deep
water I am cactus.
If you take out the plastic trim panel on the RHS of the boot, there is a pretty big area you can use for hiding a radio. There is a conduit channel running the length of the inside of the car just inside the RHS doors (unclip the door protective steps to get into it) and the grommet on the front of the firewall has a few spare nipples to get power and aerial wires thru. Try and avoid running wires down the centre of the car because of driveline interference.
Under the window on the right of the boot, I had a factory speaker sitting on a galv frame which fixed to the body in 3
places. I tek screwed on the
HF radio cradle to this and it all fits in place nicely, is
well hidden and cables are hidden and protected.
The other option I am still looking at is removing the rear grab handles above the boot windows and putting in a fixed shelf just under the roof for this stuff and a PC.
139504
Reply By: Member - Mal B - Tuesday, Nov 15, 2005 at 21:38
my coden is mounted under the passenger set of the 80 series gxl with remote head next to gear lever aerial on mount at rear. fitted new 18 mts ago (sofar ok) safe driveing mal
139565
Reply By: Willem - Tuesday, Nov 15, 2005 at 22:36
My old 6924 Codan stands behind the centre console ockey strapped to the console. Should I sink the truck in a
creek I could quickle grab it and the Satphone and jump into a life raft....lol
Now and then I may listen to VKS but on the whole it just sits there waiting to be used in anger.
139582
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Nov 15, 2005 at 22:42
Hmmm removeable eh? could be a good way to combat light fingered locals
393278
Follow Up By: Willem - Tuesday, Nov 15, 2005 at 22:52
Hahahahahahaha....who the hell would want to steal dinosaur technology. Most of these radios are in museums
Its like the bloke in the USA who tried to get rid of his Ford Pinto. He left it in a popular shopping mall car
park with the windows open and the keys in it. Three weeks later it was still there...untouched
393279
Follow Up By: geocacher (djcache) - Tuesday, Nov 15, 2005 at 23:01
Nothing wrong with a 6924 Willem. Not many 1969 vehicles work as
well after they've done as many kms as some of those radios.
Davoe,
In my dual cab I have the transceiver of the
HF Radio (was 9323 but changing to NGT at present) behind the back
seat and the remote head up front.
I've seen antenna's left in place and
the tip tied back to the
snorkel flexing the antenna down and out of the way of obstacles but able to be raised if needed. Radio can still be left on scan / selcall watch (if fitted) that way too.
393281
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Nov 15, 2005 at 23:08
Willem when I moved into the caravan at the pistol club as caretaker it was after about 3 break ins so i went down to the 2nd hand
shop and bought a tv and video i thought no one would take. The video had the front panel busted off and no remote - you couldnt have given it away at the pub. Came back from the movies and they had taken my brand new (but fairly cheap akai) stereo off of the video and flogged it - Many of the locals here were born to steal and they dont care what it is
393283
Follow Up By: Willem - Tuesday, Nov 15, 2005 at 23:22
Yeah Davoe I know where you are coming from.
You need to consolidate your trust fund and move to a happier place :o)
393285
