Extra fuel or water
Submitted: Tuesday, Nov 15, 2005 at 09:10
ThreadID: 28101 Views:2421 Replies:6 FollowUps:10
I'm heading to the Kimblery and Pilbra region for 6mths next year and hoping for some advice. Have a patrol cab chassis towing a pioneer camper. Camper will have 60 litres of water under floor, 4x4 has 80 litres of water under tray and approx 30+ litres in the tray so all up approx 170-180 litres.
Fuel volume is 170 litres in two standard patrol tanks.
We will have plenty of time to stay in good locations and hope to travel to some of the more remote places if possible.
So the question is what do I put in the draw bar jerry can rack (takes 3 x 20 litre drums) extra fuel or water??????????????
Don't know the area so hope people from over there can give me some advice.
Reply By: Member - John - Tuesday, Nov 15, 2005 at 09:19
with that much water, you don't need any more of that, would not take as much myself, maybe take 1 x 20 of extra fuel, but that would be all, plenty of fuel and water available. Hope this helps?
John and Jan
AnswerID: 139450
Reply By: myfourby - Tuesday, Nov 15, 2005 at 09:19
How many people will be using your water?
-myfourby
AnswerID: 139451
Follow Up By: Austravel - Tuesday, Nov 15, 2005 at 12:44
True, didn't give enough detail. Only 2 adults, but hope to stay in the one place for as long as we want if worth it, my guess would be up to a week. I have the space so thought why not use it. Initially I thought fuel as I could then buy when cheaper.
FollowupID: 393182
Follow Up By: myfourby - Tuesday, Nov 15, 2005 at 13:14
You already have a lot of both of these liquids for 2 people - really depends on how long you intend on staying in one place. To be honest I wouldn't really want to weigh down your rig much more than it already is with liquid.
Be careful not to overload - as this can quickly become the biggest problem you have (with suspension/mechanical failure being the main issues).
I'd consider leaving the jerry holders empty. - if you find you want them further down the track - most servos will sell them. Don't just take them to save on fuel prices - you might lose out when it comes time to recover your vehicle due to suspension or other mechanical failure because of overloading.
Your choice, however - we managed to get around OZ in a 2.8 hilux with 140 litres of diesel and 120 litres of water going upto 2 weeks before we needed to refill water (including a shower or two!) and 1200kms before diesel looked low. We did not do the canning or any other long distance trip though - reconsider if you plan an extended trip such as this.
-myfourby
FollowupID: 393193
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Nov 15, 2005 at 17:35
100 litres used to easily do 2 adults on a previos job for a week but if you take showers every day that could make a difference. Also most of the time it was winter
FollowupID: 393233
Reply By: flappa - Tuesday, Nov 15, 2005 at 15:44
You are potentially adding 20 or more kilo's of weight and its possible side effects to save . . . what . . . $2 - $3 on fuel.
AnswerID: 139499
Follow Up By: Austravel - Tuesday, Nov 15, 2005 at 15:47
I get your drift but it's more like 60 kg and based on my mates trip around Oz this year the range of prices in some areas was around 70-80 cents per litre dearer within a days drive.
I get the argument though hence my reason for asking.
FollowupID: 393212
Follow Up By: flappa - Tuesday, Nov 15, 2005 at 15:52
Sorry, it was someone else that said , chuck on 1 X 20l jerry , I thought it was you.
Yep , 3x20 would be 60odd kg , and yes , 60l could save a few dollars , but , that 60l puts a penalty on the vehicle and trailer.
Personally , I would want the weight as low as possible , rather then trying to save a few bucks. I WOULD though , chuck the empty Jerries on, in case.
FollowupID: 393213
Follow Up By: Austravel - Tuesday, Nov 15, 2005 at 15:55
That's what I've been wondering. Not to necessarily have them full all the time only when needed.
But wasn't sure in those areas whether water or fuel would be more of an issue. Probably will just go for fuel jerry cans and fill only when I need them or it could save serious $$.
FollowupID: 393214
Follow Up By: flappa - Tuesday, Nov 15, 2005 at 16:19
IMO , you should always carry more water then you are likely to need.
No water ,will kill you , not having spare fuel wont.
You never know when something is likely to happen busted tank , or , you come across someone in distress.
Of course fuel IS important , but , unless the extra is ACTUALLY needed , I personally , wouldn't just carry it , "because it was cheap".
FollowupID: 393216
Reply By: Willem - Tuesday, Nov 15, 2005 at 22:31
In all my years of tyravelling I have only carried 40 litres of water, filling up the containers at every available opportunity.
Next year however is going to be a another 3 month trek through the North West staying in camps for longer periods and we will be carrying 100lts water and around 300lts diesel. Towing a bush trailer not CT
We seem to use on average, 10lts water per day, including wash/shower for 2 people and a dog.
Even in remote places in the North West there is surface water that can be collected and used.
AnswerID: 139579
Follow Up By: Austravel - Wednesday, Nov 16, 2005 at 10:25
Yep probably just overkill. Have the space so have the need to fill it!! May just take some empty drums and if needed will fill them then.
FollowupID: 393312
Reply By: The Rambler( W.A.) - Tuesday, Nov 15, 2005 at 22:49
I agree with Willem and others as I have teravelled all over the top end for many years and never carried more than 60 l. of water.Remember that in the top end there is water every where that you are likely to be camping, so showers are from the river and drinking is all you need to worry about---and the beer usually takes preference.As said keep your weight down to a minimum as that is what can cause you hassles with suspension problems and tyre wear.Just my 2 cents worth but I can say that I have been through the learning curve.
AnswerID: 139584
Follow Up By: Austravel - Wednesday, Nov 16, 2005 at 10:27
Thanks. Will probably do as you suggest. My drama is if the space is there I feel the urge to put something else in. I guess in my travels over the past 20 years I've never taken as much but now with a camper and ute there's sooooooo much space. Also hope to be doing more trips that include staying in the one place longer.
FollowupID: 393313
Reply By: MrMagoo - Sunday, Nov 27, 2005 at 01:11
Sounds like your set up for some long stays a long way from facilities. Hmm - how about fixing a crate to the drawbar and filling it with beer cans. Full ones.
AnswerID: 141170
Follow Up By: Austravel - Monday, Nov 28, 2005 at 09:53
Now that's more along the lines I was thinking. :-) Plenty of space in the canopy for that.
FollowupID: 394938
